brgr88 wrote:If I use a powered USB hub with my RPi ModelB, as well as plugging in the RPi's normal mini-USB power cord, will the 2 power sources work in combination with each other as far as amperage is concerned?
For instance, the Pi board draws 700mA. But my USB hub's power supply is only 500mA. I'm assuming using just my USB hub's power supply, at 500mA, won't be enough to power both the Pi and my USB devices.
But if I also plug in the Pi's own mini-USB power cord (1A), would this give me an effective combined total of 1.5A (1A + 500mA) or is this not how the Pi works, power-wise?
I was curious to find this out before I invest in a more expensive powered USB hub.
Unless you're certain that your "powered" USB hub does not "back-power"** it's probably not a good idea to use two separate power supplies. A good powered (4-port) hub should have (be used with) a 1.5 - 2A PSU, since all four ports may require 500 mA. My personal preference is to use a 1.5A or 2A "multi-port" USB power supply to power the Pi and hub via separate leads. Another, single supply option, is to use a powered hub that has a"charging port" (which can supply more than 500mA) and power the Pi via that. Of course, if you're not concerned about bypassing the Pi's polyfuse and overvoltage protection you can use a single supply with a "back-powering" hub and power both that way. W.r.t. total current flow and the relative currents from each of two separate supplies, you also have to take account of the exact voltage of each supply and any effective series resistances (internal, cable, polyfuse etc.) so it's not a "simple sum".
Trev.
** Examples of "non-back-powering" hubs (which meet the USB specs.) and "back-powering" hubs (which don't) can be found here:
http://www.cpmspectrepi.webspace.virgin ... esChk.html
