Batteriesnotincluded
My RPi won't connect to internet
Sun Apr 27, 2014 8:49 pm
Hello all!
I have a small Ethernet network and also a wireless home network, and I tried connecting bot to my RPi by using the wifi co fig on the home screen, clicked scan, and nothing came up. I tried it several times, but still nothing. It came up an error when I tried typing in my network info, the error said something about the settings of the wifi config, so I typed sudo raspi-config to see if that was the cause, but, still no luck. Any help?
Re: My RPi won't connect to internet
Sun Apr 27, 2014 9:09 pm
Please post the output from the following commands:
lsusb
ifconfig -a
route -n
cat /etc/network/interfaces
cat /etc/wpa_supplicant/wpa_supplicant.conf # you may want to redact passwords
ping -c3 192.168.ggg.ggg # gateway address from route -n command
ping -c3 8.8.8.8
cat /etc/resolv.conf
ping -c3 google.com
iamabighugenerd
Tue Apr 29, 2014 4:16 pm
it appears this thread was dropped so ill pick it up for a hopeful bump
lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 005: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 006: ID 192f:0916 Avago Technologies, Pte.
Bus 001 Device 007: ID 040b:2000 Weltrend Semiconductor
Bus 001 Device 008: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
ifconfig -a
eth0 Link encap:Ethernet HWaddr b8:27:eb:dd:06:2c
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:16436 Metric:1
collisions:0 txqueuelen:0
wlan0 Link encap:Ethernet HWaddr 00:0f:55:0b:4f:84
route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
cat: /etc/wpa_supplicant/wpa_supplicant.conf: Permission denied
pinging ip addies will give me a no network error so no neeed to type all that -
cat/etc/resolv.conf
nameserver 8.8.8.8
everything worked fine when i got the pi two weeks ago but now nothing - ive done a great many things to all the wifi dongles files - long story - boring - many forum posts offer all sorts of different advice and ive tried at least 50 of them before posting one of my own - no exaggeration ive been at it for a few days - anybody with ideas please would be greatly appreciated -
Tue Apr 29, 2014 5:08 pm
Take a closer look at /etc/wpa_supplicant/wpa_supplicant.conf
sudo nano /etc/wpa_supplicant/wpa_supplicant.con
Check that you have the right network SSID and network passwords in there. Beware they are cAsE sEnSiTiVe as in "FOO" does not match "foo".
iamabighugenerd
Tue Apr 29, 2014 5:36 pm
doh - router mistakenly in wep - all this time in wep - two whole days i looked right at the thing and thought it was in wpa - thank you for your rapid response - i apologize for my stupidity
Tue Apr 29, 2014 9:45 pm
iamabighugenerd wrote:doh - router mistakenly in wep - all this time in wep - two whole days i looked right at the thing and thought it was in wpa - thank you for your rapid response - i apologize for my stupidity
WEP is Badness® In fact it's the Much More Badness® version. I think it's down to about five seconds before the hacker in the van in your street is connected to your WEP network. WPA is better, WPA2 is best (if you don't have an ancient HP 6840 printer that can't support WPA2).
