Dear all,
I have had my Pi (B) for about 6 months, and extremely happy so far with it.
Unfortunately, in that period I (?) have managed to "destroy" the HDDs I attach to the Pi. After a while, they begin with the "clicking sound of death", which I presume being caused by bad sectors in the disk. It has happened to both disks so far and now I don't want to buy another disk just to see it fail a couple of months later, and I don't think warranty would cover these.
I believe this is due to my misuse of the disks attached to the Pi. I have a AC/USB 2.5A capable power supply, which I connect to the Pi (USB). Then my HDD to the other USB port (it powers up the Pi when I attach the HDD, powers down when I detach it).
My way of "turning the Pi on" is merely by connecting the HDD to it through direct USB. To "turn the Pi off" (which I do whenever I am no longer using it), I just power down XBMC (throught the shutdown button), do a halt through ssh or unplug the HDD (when XBMC/remote crashes or I wish to power it down faster).
I believe the latter is causing the issues. Maybe hot-plugging on and off the HDD is not the way to go. Sometimes my TV remote does not (or no longer does) control XBMC and I have to restart it, and I do it by unplugging/plugging back the HDD.
Would too much of this start the disk making those clicks? Could it be power issues?
What is the recommended way to turn it off without hurting the hard disks?
If important, the screwed disks are WD and Toshiba (500GB) mobile (2.5"). Services I normally have on are only RPi-Monitor and (occasionally) Transmission.
Thanks!
