davidsstar
GUI unavailible in Raspbian when root on USB
Fri Apr 25, 2014 12:08 am
I'm trying to use a USB stick for Raspbian root directory, instead of an SD card.
So far I have:
1) extracted root.tar.xz to an ext4 formatted USB stick (Raspbian “wheezy” OS, from NOOBS download page)
2) extracted boot.tar.xz to a FAT32 formatted SD card (Raspbian “wheezy” OS, from NOOBS download page)
3) edited boot cmdline.txt flag to "root=/dev/sda1"
The pi boots up nicely into command line but as soon as I try startx the raspbian reports: "unable to connect to X server: No such file or directory"
I don't suppose there is a simple answer to this, like a script somewhere on root that I can edit, so that raspbian "knows" root resides in dev/sda1, not dev/mmcblk0p2?
btw: I have a 512mb sd card for my root directory and a 4gb usb stick for root. I have not tried installing using noobs, seeing as this would be impossible with such a small sd card.
Thanks for your consideration,
Davíð James
Aydan
Re: GUI unavailible in Raspbian when root on USB
Fri Apr 25, 2014 11:37 am
I think you may have a permissions or ownership problem from extracting the archives.
The way I'd do it is DD a working root partition from an SD card to your USB stick.
Regards
Aydan
ShiftPlusOne
Fri Apr 25, 2014 11:46 am
It's important to use the p flag when compressing and extracting. It's better to rsync -av the files across, anyway.
gkreidl
Fri Apr 25, 2014 1:22 pm
Minimal Kiosk Browser (kweb)
davidsstar
Fri Apr 25, 2014 11:37 pm
Great advice guys. I will give all the suggestions a try and report back here tomorrow for anyone that might be interested.
Cheers,
Davíð
