Hi all, I have a 750gb Seagate FreeAgent USB drive which is formatted as ext4, when I plug it into any of my Linux boxes it either automounts or shows up in /dev as /dev/sdb or similar, BUT ! when I plug it in to my Raspberry Pi ( I plug it in before I boot it ) it shows up in /dev/ as /dev/sda but there are no /dev/sda1 or sda2 entries so obviously I can't mount it - any ideas ? the drive has about 200gb of flac files on it which I want to share using the Pi. TIA
I get this from dmesg
Code:
108.190853] EXT4-fs (sda): bad block size 16384
And this from fdisk
Code:
Disk /dev/sda: 750.2 GB, 750156374016 bytes
255 heads, 63 sectors/track, 91201 cylinders, total 1465149168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x0007c34f
Device Boot Start End Blocks Id System
