bfinio wrote:I wasn't sure if it was better to post this here or in "Recommended Peripherals", so please let me know if this should be moved. I figured this might be a little more advanced than typical questions there.
My question: it's my understanding, based on
the official Raspberry Pi FAQ,
the wiki, and numerous forum threads like
this one, is that the Raspberry Pi has a 1.1A polyfuse on the micro-USB input, which limits the
total current that the Pi+any peripherals can draw to 1.1A.
I understand that it's worth using a power supply slightly bigger than 1.1A because:
Picking the right power supply is science on It's own
A one for all might seem a good Idea, but It depends
On what you are going to feed from It
High current o/p power supply's contain highly inductive
And reactive components, these can generate noise
Spikes and transients,( basically all the same )
These can cause problems with the Pi
My advice is have a 5v 1.5a good quality well filtered
Power supply just for the Pi.
Pick e power supply at the voltage and current
Of your choyse, for your peripherals.
Don't cut corners with the power supply for the Pi
- you can get a more stable voltage by not stressing the power supply to its limits
- sizes like 1.5A may be more common than 1.1A, 1.2A etc; and 1.0A is too low
However, given the existence of the 1.1A polyfuse, I can't figure out the purpose of a
2A supply. I think I've even seen 3A supplies marketed. Unless I'm really missing something, there's no way to draw that much current directly through the Pi (not counting splitting the cable for some custom setup), and I have a hard time believing that you get any added "more stable voltage" benefits by moving up to 2.0A from 1.5A.
You can see my email exchange with ModMyPi support about this in
this thread on Reddit. I also started a
new thread there but figured I would get a better answer here.
