Trismatism
Ethernet is not working :(
Tue Apr 22, 2014 1:38 am
So i have the Model B, Revision 1 board, and no matter what OS, and no matter what cable, I CANNOT get the ethernet to work on my pi /: I've read that there have been problems with the crystal (x1), but I am a dud when it comes to my soldering skills. Also, usb is working just fine. Can anyone tell me whats up, and maybe how to fix it? :cry:
Burngate
Re: Ethernet is not working :(
Tue Apr 22, 2014 10:32 am
If the USB is working - keyboard, mouse, etc. - then there isn't a problem with the crystal, or at least the main part of the USB/Ethernet chip.
Revision 1 is quite old, now. Do you know its history? Could there be damage to the RJ45 socket?
What's on the other end of the ethernet cable?
MaxK1
Tue Apr 22, 2014 12:19 pm
What Burngate said + what, if any, LEDS light up? Anything in the log (dmesg output)?
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
Trismatism
Tue Apr 22, 2014 4:36 pm
As far as history of the board, it's never suffered any damage or anything, and I am the only one who has ever used it. My modem (Net gear N450 CG3000Dv2) is on the other end of the ethernet cable. I know the modem works because I tested all my ethernet cables. I guess it has taken me this long to find out I couldn't get ethernet because I havent really been able to use it.
How would I look at dmesg? (I'm a novice with Linux currently. I'm trying to fix that)
Also, the only LED that lights up is power, and sometimes the LED that is labled OK.
MrEngman
Tue Apr 22, 2014 4:51 pm
To view dmesg, using command dmesg on its own will print all the boot log data in one go, but then most will scroll off the top of the screen. You can save it to a file using dmesg > dmesg.txt for example and then view it with a text editor. An alternative which will enable you to scroll back and forth through the dmesg data is to use the command dmesg | less and you can scroll through the data using the up and down arrow keys to look for problems, then type q to quit.
MrEngman
abishur
Tue Apr 22, 2014 4:59 pm
Are you using this headless or do you have a screen attached?
Dear forum: Play nice ;-)
MaxK1
Tue Apr 22, 2014 5:00 pm
Check inside the ethernet connector (on the Pi) for a mis-aligned or bent pin. The LEDs for ethernet should come on very shortly after power is applied IIRC _IF_ both ends are connected. Try pushing the connector all the way in to see if that makes a difference.
The dmesg command will tell you a lot of stuff about what the kernel detected during boot up.
Trismatism
Tue Apr 22, 2014 7:31 pm
The pi is hooked up to my Samsung TV via hdmi, so it isn't headless. I did check the Ethernet connect, and there were know misaligned or bent pins. The light blinked real fast once on startup, but that was it. Also, in case it helps, i am currently using Pidora.
Here is dmesg (Because it wouldnt let me attach a .txt file):
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.6.11 (mockbuild@) (gcc version 4.7.2 20120921 (Red Hat 4.7.2-2) (GCC) ) #1 PREEMPT Fri Jun 14 13:05:58 EDT 2013
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 49152
[ 0.000000] free_area_init_node: node 0, pgdat c072fc64, node_mem_map c0806000
[ 0.000000] Normal zone: 384 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 48768 pages, LIFO batch:15
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 48768
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1794 bcm2708_fb.fbheight=954 bcm2708.boardrev=0x2 bcm2708.serial=0x2a4f3921 smsc95xx.macaddr=B8:27:EB:4F:39:21 sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0xec00000 vc_mem.mem_size=0x10000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait quiet
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 192MB = 192MB total
[ 0.000000] Memory: 186600k/186600k available, 10008k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xcc800000 - 0xff000000 ( 808 MB)
lowmem : 0xc0000000 - 0xcc000000 ( 192 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc06b2460 (6826 kB)
.init : 0xc06b3000 - 0xc06df754 ( 178 kB)
.data : 0xc06e0000 - 0xc07341c8 ( 337 kB)
.bss : 0xc07341ec - 0xc0805708 ( 838 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:330
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] timer_set_mode: unhandled mode:1
[ 0.000000] timer_set_mode: unhandled mode:3
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.000376] Calibrating delay loop... 464.48 BogoMIPS (lpj=2322432)
[ 0.060069] pid_max: default: 32768 minimum: 301
[ 0.060303] Security Framework initialized
[ 0.060337] SELinux: Initializing.
[ 0.060411] SELinux: Starting in permissive mode
[ 0.060681] Mount-cache hash table entries: 512
[ 0.061572] Initializing cgroup subsys cpuacct
[ 0.061597] Initializing cgroup subsys devices
[ 0.061610] Initializing cgroup subsys freezer
[ 0.061621] Initializing cgroup subsys net_cls
[ 0.061754] CPU: Testing write buffer coherency: ok
[ 0.062053] hw perfevents: enabled with v6 PMU driver, 3 counters available
[ 0.062171] Setting up static identity map for 0x4cb458 - 0x4cb4b4
[ 0.064255] devtmpfs: initialized
[ 0.074639] dummy:
[ 0.075060] NET: Registered protocol family 16
[ 0.079949] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.081191] bcm2708.uart_clock = 0
[ 0.083095] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.083113] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.083127] mailbox: Broadcom VideoCore Mailbox driver
[ 0.083218] bcm2708_vcio: mailbox at f200b880
[ 0.083302] bcm_power: Broadcom power driver
[ 0.083320] bcm_power_open() -> 0
[ 0.083331] bcm_power_request(0, 8)
[ 0.584012] bcm_mailbox_read -> 00000080, 0
[ 0.584029] bcm_power_request -> 0
[ 0.584039] Serial: AMBA PL011 UART driver
[ 0.584156] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 0.592975] console [ttyAMA0] enabled
[ 0.615390] bio: create slab <bio-0> at 0
[ 0.616633] SCSI subsystem initialized
[ 0.616961] usbcore: registered new interface driver usbfs
[ 0.617048] usbcore: registered new interface driver hub
[ 0.617313] usbcore: registered new device driver usb
[ 0.618099] Advanced Linux Sound Architecture Driver Version 1.0.25.
[ 0.618787] NetLabel: Initializing
[ 0.618808] NetLabel: domain hash size = 128
[ 0.618816] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.618884] NetLabel: unlabeled traffic allowed by default
[ 0.619383] Switching to clocksource stc
[ 0.661230] NET: Registered protocol family 2
[ 0.662129] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.662360] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.662494] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.662536] TCP: reno registered
[ 0.662562] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.662593] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.662992] NET: Registered protocol family 1
[ 0.664052] bcm2708_dma: DMA manager at f2007000
[ 0.664165] bcm2708_gpio: bcm2708_gpio_probe c06eeb08
[ 0.669784] vc-mem: phys_addr:0x00000000 mem_base=0x0ec00000 mem_size:0x10000000(256 MiB)
[ 0.670192] major device number 251
[ 0.670213] vma list size 12, page list size 2008, page size 4096
[ 0.670230] allocated dma channel 2 (f2007200), initial state 00000008
[ 0.670238] post-reset 00000008
[ 0.671060] audit: initializing netlink socket (disabled)
[ 0.671138] type=2000 audit(0.660:1): initialized
[ 0.824712] VFS: Disk quotas dquot_6.5.2
[ 0.825032] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.828291] msgmni has been set to 364
[ 0.828715] SELinux: Registering netfilter hooks
[ 0.831339] alg: No test for stdrng (krng)
[ 0.831759] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.831781] io scheduler noop registered
[ 0.831794] io scheduler deadline registered
[ 0.831850] io scheduler cfq registered (default)
[ 0.858926] Console: switching to colour frame buffer device 224x59
[ 0.878371] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.880249] serial8250.0: ttyS0 at MMIO 0x20215040 (irq = 29) is a 8250
[ 0.880714] kgdb: Registered I/O driver kgdboc.
[ 0.891213] brd: module loaded
[ 0.896823] loop: module loaded
[ 0.897276] vchiq: vchiq_init_state: slot_zero = 0xcc804000, is_master = 0
[ 0.899177] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[ 0.900281] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 0.900489] usbcore: registered new interface driver cdc_ether
[ 0.900626] usbcore: registered new interface driver smsc95xx
[ 0.900710] usbcore: registered new interface driver rndis_host
[ 0.900858] usbcore: registered new interface driver cdc_ncm
[ 0.900917] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.106040] Core Release: 2.80a
[ 1.106070] Setting default values for core params
[ 1.106114] Finished setting default values for core params
[ 1.311243] Using Buffer DMA mode
[ 1.311266] Periodic Transfer Interrupt Enhancement - disabled
[ 1.311276] Multiprocessor Interrupt Enhancement - disabled
[ 1.311288] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.311305] Dedicated Tx FIFOs mode
[ 1.311573] dwc_otg: Microframe scheduler enabled
[ 1.311628] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.311684] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.311748] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.311821] Init: Port Power? op_state=1
[ 1.311831] Init: Power Port (0)
[ 1.311956] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.311978] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.311995] usb usb1: Product: DWC OTG Controller
[ 1.312009] usb usb1: Manufacturer: Linux 3.6.11 dwc_otg_hcd
[ 1.312023] usb usb1: SerialNumber: bcm2708_usb
[ 1.312979] hub 1-0:1.0: USB hub found
[ 1.313026] hub 1-0:1.0: 1 port detected
[ 1.313445] dwc_otg: FIQ enabled
[ 1.313462] dwc_otg: NAK holdoff enabled
[ 1.313484] Module dwc_common_port init
[ 1.313730] Initializing USB Mass Storage driver...
[ 1.313948] usbcore: registered new interface driver usb-storage
[ 1.313963] USB Mass Storage support registered.
[ 1.314133] usbcore: registered new interface driver libusual
[ 1.314337] usbcore: registered new interface driver usbserial
[ 1.314430] usbcore: registered new interface driver usbserial_generic
[ 1.314498] USB Serial support registered for generic
[ 1.314514] usbserial: USB Serial Driver core
[ 1.315173] mousedev: PS/2 mouse device common for all mice
[ 1.315830] i2c /dev entries driver
[ 1.316554] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100k)
[ 1.317091] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100k)
[ 1.318391] device-mapper: uevent: version 1.0.3
[ 1.319098] device-mapper: ioctl: 4.23.0-ioctl (2012-07-25) initialised: dm-devel@redhat.com
[ 1.319614] device-mapper: multipath: version 1.5.0 loaded
[ 1.319640] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 1.320053] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 1.320171] bcm2835-cpufreq: switching to governor ondemand
[ 1.320189] bcm2835-cpufreq: switching to governor ondemand
[ 1.320277] cpuidle: using governor ladder
[ 1.320293] cpuidle: using governor menu
[ 1.320367] sdhci: Secure Digital Host Controller Interface driver
[ 1.320380] sdhci: Copyright(c) Pierre Ossman
[ 1.320497] sdhci: Enable low-latency mode
[ 1.320607] mmc0: no vmmc regulator found
[ 1.320815] Registered led device: mmc0::
[ 1.359655] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 1.359727] mmc0: BCM2708 SDHC host at 0x20300000 DMA 0 IRQ 16
[ 1.359824] VUB300 Driver rom wait states = 1C irqpoll timeout = 0400
[ 1.362690] usbcore: registered new interface driver vub300
[ 1.362715] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.366201] Registered led device: led0
[ 1.376228] usbcore: registered new interface driver usbhid
[ 1.376250] usbhid: USB HID core driver
[ 1.383071] drop_monitor: Initializing network drop monitor service
[ 1.383669] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.383820] TCP: cubic registered
[ 1.383838] Initializing XFRM netlink socket
[ 1.384907] NET: Registered protocol family 10
[ 1.386038] NET: Registered protocol family 17
[ 1.386311] Key type dns_resolver registered
[ 1.386797] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 1.388018] registered taskstats version 1
[ 1.388502] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 1.396585] bcm2835 ALSA card created!
[ 1.396796] bcm2835 ALSA chip created!
[ 1.396954] bcm2835 ALSA chip created!
[ 1.397104] bcm2835 ALSA chip created!
[ 1.397254] bcm2835 ALSA chip created!
[ 1.397402] bcm2835 ALSA chip created!
[ 1.397549] bcm2835 ALSA chip created!
[ 1.397699] bcm2835 ALSA chip created!
[ 1.397913] ALSA device list:
[ 1.397931] #0: bcm2835 ALSA
[ 1.398305] md: Waiting for all devices to be available before autodetect
[ 1.398328] md: If you don't use raid, use raid=noautodetect
[ 1.399323] md: Autodetecting RAID arrays.
[ 1.399347] md: Scanned 0 and added 0 devices.
[ 1.399357] md: autorun ...
[ 1.399363] md: ... autorun DONE.
[ 1.400157] Waiting for root device /dev/mmcblk0p2...
[ 1.411809] mmc0: could read SD Status register (SSR) at the 2th attempt
[ 1.415983] mmc0: new high speed SDHC card at address 1234
[ 1.416587] mmcblk0: mmc0:1234 SA16G 14.6 GiB
[ 1.418717] mmcblk0: p1 p2
[ 1.510120] Indeed it is in host mode hprt0 = 00021501
[ 1.523715] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.523744] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.689530] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.689706] Indeed it is in host mode hprt0 = 00001101
[ 1.889826] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 1.889855] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.890833] hub 1-1:1.0: USB hub found
[ 1.890997] hub 1-1:1.0: 3 ports detected
[ 2.169597] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.270154] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.270182] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.273320] smsc95xx v1.0.4
[ 2.338145] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:4f:39:21
[ 2.429820] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
[ 2.530693] usb 1-1.3: New USB device found, idVendor=8301, idProduct=0089
[ 2.530722] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.538572] input: HID 8301:0089 as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input0
[ 2.539286] hid-generic 0003:8301:0089.0001: input,hidraw0: USB HID v1.10 Keyboard [HID 8301:0089] on usb-bcm2708_usb-1.3/input0
[ 2.543747] input: HID 8301:0089 as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input1
[ 2.544662] hid-generic 0003:8301:0089.0002: input,hidraw1: USB HID v1.10 Mouse [HID 8301:0089] on usb-bcm2708_usb-1.3/input1
[ 8.632284] EXT4-fs (mmcblk0p2): recovery complete
[ 9.499385] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 9.499551] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 9.501339] devtmpfs: mounted
[ 9.502007] Freeing init memory: 176K
[ 9.941046] SELinux: Disabled at runtime.
[ 9.941193] SELinux: Unregistering netfilter hooks
[ 9.941304] type=1404 audit(9.930:2): selinux=0 auid=4294967295 ses=4294967295
[ 9.995808] systemd[1]: systemd 195 running in system mode. (+PAM +LIBWRAP +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ; fedora)
[ 10.087321] systemd[1]: Inserted module 'autofs4'
[ 10.090190] systemd[1]: Set hostname to <raspi.local>.
[ 10.597836] systemd[1]: Starting Login Prompts.
[ 10.598084] systemd[1]: Reached target Login Prompts.
[ 10.598281] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 10.599054] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 10.599247] systemd[1]: Starting Remote File Systems.
[ 10.599550] systemd[1]: Reached target Remote File Systems.
[ 10.599722] systemd[1]: Starting Syslog Socket.
[ 10.600280] systemd[1]: Listening on Syslog Socket.
[ 10.600470] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 10.600817] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 10.600982] systemd[1]: Starting Delayed Shutdown Socket.
[ 10.601337] systemd[1]: Listening on Delayed Shutdown Socket.
[ 10.601504] systemd[1]: Starting Device-mapper event daemon FIFOs.
[ 10.601924] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 10.602098] systemd[1]: Starting Encrypted Volumes.
[ 10.602277] systemd[1]: Reached target Encrypted Volumes.
[ 10.602699] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 10.603696] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 10.603943] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 10.604459] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 10.605348] systemd[1]: Starting udev Kernel Socket.
[ 10.605758] systemd[1]: Listening on udev Kernel Socket.
[ 10.606481] systemd[1]: Starting udev Control Socket.
[ 10.607016] systemd[1]: Listening on udev Control Socket.
[ 10.607259] systemd[1]: Starting Journal Socket.
[ 10.607886] systemd[1]: Listening on Journal Socket.
[ 10.608097] systemd[1]: Starting Syslog.
[ 10.608280] systemd[1]: Reached target Syslog.
[ 10.608551] systemd[1]: Starting File System Check on Root Device...
[ 10.613597] systemd[1]: Started Import network configuration from initramfs.
[ 10.613827] systemd[1]: Starting Start Rasp Pi Boot Screen...
[ 10.634591] systemd[1]: Started Set Up Additional Binary Formats.
[ 10.653168] systemd[1]: Starting Apply Kernel Variables...
[ 10.657921] systemd[1]: Starting udev Coldplug all Devices...
[ 10.675038] systemd[1]: Starting Journal Service...
[ 10.686076] systemd[1]: Started Journal Service.
[ 10.688542] systemd[1]: Starting udev Kernel Device Manager...
[ 10.707672] systemd[1]: Started Load Kernel Modules.
[ 10.708034] systemd[1]: Mounted FUSE Control File System.
[ 10.708246] systemd[1]: Starting time and date fix for devices with no RTC...
[ 10.719703] systemd[1]: Starting boot.automount.
[ 10.724849] systemd[1]: Set up automount boot.automount.
[ 10.927230] systemd-udevd[58]: starting version 195
[ 12.019648] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 12.938549] systemd-journald[56]: Received SIGUSR1
[ 13.322115] Adding 524284k swap on /swap0. Priority:-1 extents:4 across:2105340k SS
[ 22.140571] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.140646] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.214824] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.214900] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.216033] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.216105] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.217223] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.217290] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.218388] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.218461] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.219593] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.219667] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.225857] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.225935] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.227052] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.227125] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.228196] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.228262] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.229301] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.229372] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.231605] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.231679] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.232742] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.232813] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.233859] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.233923] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.234965] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.235037] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.236083] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.236153] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.237174] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.237242] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.238268] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.238330] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.239376] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.239547] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.241732] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.241805] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.242818] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.242890] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.243878] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.243941] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.244934] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.245005] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.246213] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.246324] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.247611] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.247687] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.248885] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.248951] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.250084] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.250152] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.251272] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.251343] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.252531] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.252607] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.253764] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.253836] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.255051] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.255121] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.256253] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.256325] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.257479] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.257549] mmc0: DMA IRQ 6 ignored - results were reset
[ 22.258685] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 22.258757] mmc0: DMA IRQ 6 ignored - results were reset
[ 29.169717] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 29.439794] Ebtables v2.0 registered
[ 30.506620] Bluetooth: Core ver 2.16
[ 30.506755] NET: Registered protocol family 31
[ 30.506771] Bluetooth: HCI device and connection manager initialized
[ 30.506785] Bluetooth: HCI socket layer initialized
[ 30.506796] Bluetooth: L2CAP socket layer initialized
[ 30.506865] Bluetooth: SCO socket layer initialized
[ 30.560641] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 30.560669] Bluetooth: BNEP filters: protocol multicast
[ 30.694062] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 31.036957] nf_conntrack version 0.5.0 (2918 buckets, 11672 max)
[ 150.848053] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[ 150.848185] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[ 150.848238] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[ 150.859520] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[ 150.859572] ERROR::dwc_otg_hcd_urb_enqueue:477: Not connected
[ 151.049638] usb 1-1: USB disconnect, device number 2
[ 151.049673] usb 1-1.1: USB disconnect, device number 3
[ 151.050006] smsc95xx 1-1.1:1.0: eth0: unregister 'smsc95xx' usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet
[ 151.060351] usb 1-1.3: USB disconnect, device number 4
[ 151.229569] Indeed it is in host mode hprt0 = 00021501
[ 151.469553] usb 1-1: new high-speed USB device number 5 using dwc_otg
[ 151.469764] Indeed it is in host mode hprt0 = 00001101
[ 151.729894] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 151.729928] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 151.730959] hub 1-1:1.0: USB hub found
[ 151.731122] hub 1-1:1.0: 3 ports detected
[ 152.009786] usb 1-1.1: new high-speed USB device number 6 using dwc_otg
[ 152.110186] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 152.110221] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 152.113422] smsc95xx v1.0.4
[ 152.174807] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:4f:39:21
[ 152.269718] usb 1-1.3: new full-speed USB device number 7 using dwc_otg
[ 152.370678] usb 1-1.3: New USB device found, idVendor=8301, idProduct=0089
[ 152.370711] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 152.378785] input: HID 8301:0089 as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/input/input2
[ 152.390063] hid-generic 0003:8301:0089.0003: input,hidraw0: USB HID v1.10 Keyboard [HID 8301:0089] on usb-bcm2708_usb-1.3/input0
[ 152.394432] input: HID 8301:0089 as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.1/input/input3
[ 152.402734] hid-generic 0003:8301:0089.0004: input,hidraw1: USB HID v1.10 Mouse [HID 8301:0089] on usb-bcm2708_usb-1.3/input1
[ 168.856200] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 203.899596] Bluetooth: RFCOMM TTY layer initialized
[ 203.899649] Bluetooth: RFCOMM socket layer initialized
[ 203.899664] Bluetooth: RFCOMM ver 1.11
Tue Apr 22, 2014 7:42 pm
You can see the SMSC9512/9514 coming active in that dmesg output.
So first thing is check the cable. Ethernet uses pins 1,2,3 & 6 (white/green, green/white, white/orange and orange/white if it's 568A or white/orange, orange/white, white/green & green/white if it's 568B).
If you don't have a cable tester, disable the wireless on your laptop and wire it to your router/switch/cable modem.
You can also use your laptop to connect to your RPi.
Edit /boot/cmdline.txt
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait quiet
gets updated to
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait quiet ip=169.254.3.14
boot up with that, connect the cable to your laptop and attempt to ping 169.254.3.14 (or ssh using PuTTY to 169.254.3.14).
Trismatism
Tue Apr 22, 2014 7:55 pm
gets updated to
Do you mean connect to the pi via ethernet from my computer to the pi?
Tue Apr 22, 2014 8:04 pm
Yes.
It's as quick a way to check your RPi and the cable as any. It removes a layer of complication. If the hardware works you should get pretty leds winking on both ends.
If the ping works then you know that the RPi is good to go and you need to look at your router/switch/cable modem.
You can also test with the laptop wired to the router/switch/cable modem to try to narrow down the root cause of your problems.
Trismatism
Tue Apr 22, 2014 10:35 pm
So I tried it, and assuming I did it right, it didnt work. Igot a "General Failure". I know that cable works, and the modem works fine because I have ran the cable from the modem to my pc, and disabled the wireless and still got a solid connection.
Before I did you method though, it seemed like It was trying to get a Connection. I was getting what sorta looked like swirling circles, then it would say it couldn't connect, and it bounced back and forth like that for a while, but I'm not sure why it suddenly tried to work. Is the pi just shot? Should I try replaced the ethernet connector? Or could it even be a distributor problem?
Tue Apr 22, 2014 10:51 pm
I'm not a fan of GUIs, so 99.9% of stuff that happens on my RPis is done from the command line.
First thing to look at is the power supply. The USB/Ethernet has a 300mA drain, if your supply is marginal that can be a cause of unexpected failures.
Then from a software / operating system perspective (I'm assuming you're running Raspbian or NOOBS/Raspbian) we need to look at how you've got the interfaces configured.
cat /etc/network/interfaces
ifconfig -a
route -n
I'm assuming you've got the RPi set-up to request a DHCP address from your network (which means we send some funky bootp packets out on to the LAN segment and hope that a DHCP server shouts back with a dhcp lease (and other stuff)).
We can use nmap to look for those bootp packets (although it gets difficult if you don't have a network connection trying to install the nmap package - as it can be a chicken & egg problem).
Lots of messages get logged to /var/log/dmesg, /var/log/messages and/or /var/log/syslog which can give some clues as to what's going wrong. We get folks posting camera shots with those when they can't get connected to do a cut'n'paste on to here.
So we have a plan, starting with your power supply.
