Broken_Mind
Start python script on boot
Sat Apr 19, 2014 10:33 pm
I'm trying currently in Python and I have a few questions to it.
- How can I start the python script at boot?
- How can I adjust my window as a full screen window?
- How can I place the buttons in a fix position?
Here is my code:
HOST = "127.0.0.1"
PORT = 4223
UID = "jNw"
from Tkinter import *
from tinkerforge.ip_connection import IPConnection
from tinkerforge.bricklet_remote_switch import RemoteSwitch
import os
master = Tk()
master.title("GUI")
w = Canvas(master, width=300, height=200)
w.pack()
def shutdown():
    os.system("sudo shutdown -h now")
def reboot():
    os.system("sudo shutdown -r now")
def light_on():
    if __name__ == "__main__":
    ipcon = IPConnection() # Create IP connection
    rs = RemoteSwitch(UID, ipcon) # Create device object
    ipcon.connect(HOST, PORT) # Connect to brickd
    # Don't use device before ipcon is connected
    # Switch socket with house code 17 and receiver code 1 on.
    # House code 17 is 10001 in binary (least-significant bit first)
    # and means that the DIP switches 1 and 5 are on and 2-4 are off.
    # Receiver code 1 is 10000 in binary (least-significant bit first)
    # and means that the DIP switch A is on and B-E are off.
    rs.switch_socket_b(1, 1, RemoteSwitch.SWITCH_TO_ON)
def light_off():
    rs.switch_socket_b(1, 1, RemoteSwitch.SWITCH_TO_OFF)
b=Button(master, text= "Shutdown", command=shutdown)
b.pack()
b=Button(master, text= "Reboot", command=reboot)
b.pack()
b=Button(master, text= "Licht an", command=light_on)
b.pack()
b=Button(master, text= "Licht aus", command=light_off)
b.pack()
mainloop()
friendly regards
davef21370
Re: Start python script on boot
Sun Apr 20, 2014 6:33 am
To run your script at startup open a terminal window and type sudo nano /etc/rc.local
At the end of this file add python scriptname.py & (where scriptname is the name of your script) and save that.
For full screen in Tkinter look here http://stackoverflow.com/questions/7966 ... on-tkinter and for better widget placement use grid instead of pack.
Dave.
Apple say... Monkey do !!
gkreidl
Sun Apr 20, 2014 6:56 am
full screen:
master.attributes('-fullscreen', True)
positioning elements:
use the grid() method and the sticky attribute; it's a bit "tricky". Here's a fine tutorial for TKinter:
http://infohost.nmt.edu/tcc/help/pubs/t ... index.html
For auto starting X, a windowmanager and your GUI application without going to the desktop you may use the method I've described in my Minimal Kiosk Browser manual. Just replace 'kweb' with your application.
Minimal Kiosk Browser (kweb)
Broken_Mind
Tue Apr 22, 2014 10:26 am
I tried it with Grid. But I did not work. Could you show me an example for a button?
Joe Schmoe
Tue Apr 22, 2014 10:55 am
Wrong!
(See: http://en.wikipedia.org/wiki/John_McLaughlin_(host))
Search the forum for "Best way".
Return to “Python”
