Hi Gents,
let me have a question about using i2c BUS. My problem is, that the result of the i2cdetect command is always the same as you can see on the attachment (nothing is connected to the bus).
- Bus1 shows nothing but "UU" on the address "3B" all the time with and without connecting anything to the bus.
- Bus0 showing all the addresses all the time with and without connecting anything to the bus. Strange to me...
Currently I'm using Raspberry pi model B with 256MB ram, so normally the bus0 should work. All my settings are looks correct according to the tutorials (blacklist, modprobe.d ect.)
Actually the system is running on an USB pendrive, and some SWs are installed as well..but nothing should have affect on i2c.
Am I killed the hardware? Or is this something with configurations?
Thank you for your help in advance!
Egon
- results on both i2c bus
- i2cissue.PNG (11.39 KiB) Viewed 4782 times
