Douglas6
Re: Help!!!!
Tue Apr 29, 2014 12:38 am
ame wrote:Picture a player-piano with a paper roll with holes in it to play a tune.
No, no, no. :) We want interaction. Picture a MIDI keyboard that plays the umbrellas in a live performance. Or they respond to the sound of music, like an FFT spectrum analyzer. Or perhaps use a Leap Motion device to read hand gestures. Or...heck you probably have your own ideas. The point being that it's easy now to programmatically control the servos with say, Python, in response to just about any input you can think of, it doesn't have to be predetermined. And by 'easy', I mean many frustrating hours of code debugging. :)
ame
Re: Help!!!!
Tue Apr 29, 2014 1:14 am
I was thinking baby steps first.
Douglas6
Re: Help!!!!
Tue Apr 29, 2014 1:24 am
ame wrote:I was thinking baby steps first.
Yes, good point, I got carried away.
boyoh
Re: Help!!!!
Tue Apr 29, 2014 3:25 pm
dadcanyouhelp wrote:Hi All, never heard of Raspberry Pi until about an hour ago, an assistant in Maplin told me a bit,
My daughter is in her last year at uni and is onto her final pieces, so I got one of those "can you help Dad" calls
Katie wants to Automate approx 10-20 cocktail umbrellas just to open and close in a sequence or to be pir/pressure activated,
my initial thought was to use small servo's to operate the umbrellas and have some form of transmitter/receiver set-up but then Katie said about Arduino's so i went off to maplins and hey presto i'm now trying to learn quickly about RP and hopefully get some advice and guidance from forum members PLEASE ??
Cheers
Tim
Could I suggest a CMOS Decade Counter
To con troll your project ,By buffering the
Out/puts to give you the power you require
You might only need one GPIO out/put
That you can program as a clock pulse
Timing at the speed you want.
If you want more out/puts you can
Cascade more Decade Counters
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
dadcanyouhelp
Re: Help!!!!
Tue Apr 29, 2014 9:39 pm
Amazing help so far guys! Before I fully ingest Ame's suggestions with writing some commands, we're building our first prototype with a single brolly, but we've hit a snag again...
As soon as the servo is connected up to the external power source (5v) the servo moves without us sending any commands. It moves but can still be turned by hand. When we send the echo command, it doesn't react. It was working fine yesterday; any ideas?
Yours,
Katie and Tim.
Edit: Changed pin and it worked? Will upload a photo of it soon so you can see :)
joan
Re: Help!!!!
Tue Apr 29, 2014 9:47 pm
My favourite way to use servos.
https://www.youtube.com/watch?v=HBFMTbcNLtg
boyoh
Re: Help!!!!
Wed Apr 30, 2014 3:12 pm
Cheers
Tim
well... with the right hardware and code, the Pi could do it. So could an Arduino. What are you thinking for hardware? Servos can work with the Pi, but there are probably other options that could work too.
Do remember that the Pi's GPIO pins are 3.3v with a max of 16 mA per pin with a max total of 50 mA.
It seems a good project . Opening and closing
Cocktail Umbrellas
Not being a party goer , I have never seen a
Cocktail umbrella. What are the mechanics
Of how the umbrella opens and closes
How are you linking it to the server.
Would small Solenoids do the same job
Ravenous
Re: Help!!!!
Wed Apr 30, 2014 4:02 pm
Agreed, I've been watching this thread with curiosity and don't understand how the umbrellas open. Perhaps I'm not a cocktails guy :D
Initially I thought perhaps one motor could be used with cams or levers to open all of them in one sequence, but if the sequence can change they'll definitely need one "actuator" of some sort each.
Tarcas
Re: Help!!!!
Wed Apr 30, 2014 4:28 pm
Ravenous wrote:Agreed, I've been watching this thread with curiosity and don't understand how the umbrellas open. Perhaps I'm not a cocktails guy :D
I think at one point, servos and pneumatics were each mentioned. IMO, I think pneumatics would probably be the better choice, but I'm not sure if that's still on the table since servos are all that have been discussed at length.
When I hear cocktail umbrellas I think of something like this but I'm hoping he's planning on using something a little bigger, heavier, and much more durable if he expects any machine to open it repeatedly.
Dad: Can you send a link to whatever hardware you were thinking of using, so we can see what it might be compatible with?
Ravenous
Re: Help!!!!
Wed Apr 30, 2014 4:32 pm
Can you imagine a hundred of them in a 10x10 matrix being made to "flap" scrolling messages? :o
EDIT - or simulate a Pacman game? :oops:
Burngate
Re: Help!!!!
Wed Apr 30, 2014 4:34 pm
Perhaps something like this?
Ravenous
Re: Help!!!!
Wed Apr 30, 2014 4:57 pm
How about this - forty syringes (in different sizes):
http://www.rapidonline.com/Education/Te ... wwodnpYAGA
Trouble is you would need some sort of pressure source to supply them. One could be rigged by "pumping" one of the bigger syringes with a motor, but that would need a non-return valve and probably other stuff I think.
Also it wouldn't drive them in a programmable sequence. All at once or perhaps in a fixed "wave" but for fully programmable control you would need 20 motors to go with the 20 large and 20 small syringes. The syringes would be quite compact but it'd be pretty complicated and a heckofa lot of piping...
boyoh
Re: Help!!!!
Thu May 01, 2014 10:15 pm
Cheers
Tim
Cocktail Umbrellas
This is one Idea, Might work
