oliver
motionn sensor turn led on
Tue Apr 15, 2014 2:05 pm
hi
i have been trying to make an LED turn on when i move but i dont know what is wrong with the code i am very new to python and am only 12 please help
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
PIR_PIN = 7
GPIO.setup(PIR_PIN, GPIO.IN)
GPIO.setup(11, GPIO.OUT)
GPIO.output (11, False)
try:
    print "PIR Module Test (CTRL+C to exit)"
    time.sleep(2)
    print "Ready"
    while True:
        if GPIO.input(PIR_PIN):
            print "Motion Detected!"
            GPIO.output(11, True)
        time.sleep(1)
except KeyboardInterrupt:
    print "    Quit"
    GPIO.cleanup()
thanks
olly :)
paddyg
Re: motionn sensor turn led on
Tue Apr 15, 2014 4:05 pm
Olly,
If I was trying to do this and it didn't do what I wanted I would try to find which bit of the system wasn't doing what I wanted. First I would check that I could turn the led on and off every second. Then I would test what was being read from pin 7 by just having a print(GPIO.input(PIR_PIN)) in the loop and no if statement.
Is your movement detector set up correctly to normally give 0V then 3.3V when it sees movement?
also https://groups.google.com/forum/?hl=en-GB&fromgroups=#!forum/pi3d
joan
Tue Apr 15, 2014 4:09 pm
There are at least three ways of referring to the gpios. At a guess you are using the pin numbers, P1-7 and P1-11. The code is set up to use the Broadcom numbers (where P1-7 is 4 and P1-11 is 17).
See http://elinux.org/RPi_Low-level_peripherals
oliver
Wed Apr 16, 2014 5:58 am
thanks :D
Return to “Python”
