keirvt
Unusual partition 2014-0107
Tue Apr 15, 2014 3:56 am
I Downloaded 2014-01-07-wheezy-raspbian.img and wish to mount
Running fdisk- l to get the partition start blocks it doesn't look right and produces an error message
fdisk -l 2014-01-07-wheezy-raspbian.img
You must set cylinders.
You can do this from the extra functions menu.
Disk 2014-01-07-wheezy-raspbian.img: 0 MB, 0 bytes
255 heads, 63 sectors/track, 0 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000981cb
Device Boot Start End Blocks Id System
2014-01-07-wheezy-raspbian.img1 1 8 57344 c W95 FAT32 (LBA)
Partition 1 does not end on cylinder boundary.
2014-01-07-wheezy-raspbian.img2 8 361 2831360 83 Linux
Partition 2 does not end on cylinder boundary.
The image won't mount either
mount -o loop,offset=$(( 512 * 8))    2014-01-07-wheezy-raspbian.img    ./mnt
mount: you must specify the filesystem type
Re: Unusual partition 2014-0107
Tue Apr 15, 2014 5:59 am
Your download must have failed. I get
Disk 2014-01-07-wheezy-raspbian.img: 2962 MB, 2962227200 bytes
255 heads, 63 sectors/track, 360 cylinders, total 5785600 sectors
Units = sectors of 1 * 512 = 512 bytes
2014-01-07-wheezy-raspbian.img1            8192      122879       57344    c  W95 FAT32 (LBA)
2014-01-07-wheezy-raspbian.img2          122880     5785599     2831360   83  Linux
What is the size of your (unzipped) file, and what is its MD5 checksum?
rpdom@home:ls -l 2014-01-07-wheezy-raspbian.img
-rw-r--r-- 1 rpdom rpdom 2962227200 Jan  7 23:42 /tmp/2014-01-07-wheezy-raspbian.img
rpdom@home:$ md5sum 2014-01-07-wheezy-raspbian.img
6d8e5a48ff7c6bdc0bc0983bc32f75b8  2014-01-07-wheezy-raspbian.img
jojopi
Tue Apr 15, 2014 7:01 am
keirvt wrote:Units = cylinders of 16065 * 512 = 8225280 bytes
Your version of fdisk has defaulted to cylinders instead of sectors. Try "fdisk -lu".
It is normal for partitions neither to begin nor end on a cylinder boundary these days, so a cylinder-based listing does not allow you to calculate accurate mount offsets. The modern practice is to use multiples of 1MiB or more, because traditional tracks of 63 sectors do not align properly on drives where the hardware block size is bigger than 512 bytes.
Joe Schmoe
Tue Apr 15, 2014 7:07 am
Or you can just use "file" instead of "fdisk"…
(If the goal is to get the startsector info, in order to "mount" the image file)
Return to “Raspberry Pi OS”
