Mon Feb 09, 2015 9:39 pm
Good morning
Im faced the same problem you posted, the error it's appearing to me is the following same as yours, please any help to apply in fedora(21) or windows (7) let me know. thanks in advance
[ 1510.115909] usb 2-1: USB disconnect, device number 3
Feb 9 14:17:14 localhost kernel: usb 2-1: USB disconnect, device number 3
Feb 9 14:17:14 localhost systemd-udevd: error opening USB device 'descriptors' file
Feb 9 14:17:29 localhost kernel: [ 1525.027890] usb 2-1: new high-speed USB device number 4 using ehci-pci
Feb 9 14:17:29 localhost kernel: usb 2-1: new high-speed USB device number 4 using ehci-pci
Feb 9 14:17:29 localhost kernel: [ 1525.148277] usb 2-1: New USB device found, idVendor=0930, idProduct=6545
Feb 9 14:17:29 localhost kernel: [ 1525.148295] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Feb 9 14:17:29 localhost kernel: [ 1525.148304] usb 2-1: Product: DT 101 G2
Feb 9 14:17:29 localhost kernel: [ 1525.148312] usb 2-1: Manufacturer: Kingston
Feb 9 14:17:29 localhost kernel: [ 1525.148320] usb 2-1: SerialNumber: 0018F3A9A358EB8134380115
Feb 9 14:17:29 localhost kernel: [ 1525.150380] usb-storage 2-1:1.0: USB Mass Storage device detected
Feb 9 14:17:29 localhost kernel: usb 2-1: New USB device found, idVendor=0930, idProduct=6545
Feb 9 14:17:29 localhost kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Feb 9 14:17:29 localhost kernel: usb 2-1: Product: DT 101 G2
Feb 9 14:17:29 localhost kernel: usb 2-1: Manufacturer: Kingston
Feb 9 14:17:29 localhost kernel: [ 1525.154464] scsi host5: usb-storage 2-1:1.0
Feb 9 14:17:29 localhost kernel: usb 2-1: SerialNumber: 0018F3A9A358EB8134380115
Feb 9 14:17:29 localhost kernel: usb-storage 2-1:1.0: USB Mass Storage device detected
Feb 9 14:17:29 localhost kernel: scsi host5: usb-storage 2-1:1.0
Feb 9 14:17:29 localhost mtp-probe: checking bus 2, device 4: "/sys/devices/pci0000:00/0000:00:13.2/usb2/2-1"
Feb 9 14:17:29 localhost mtp-probe: bus: 2, device: 4 was not an MTP device
Feb 9 14:17:30 localhost kernel: [ 1526.235972] scsi 5:0:0:0: Direct-Access Kingston DT 101 G2 PMAP PQ: 0 ANSI: 0 CCS
Feb 9 14:17:30 localhost kernel: scsi 5:0:0:0: Direct-Access Kingston DT 101 G2 PMAP PQ: 0 ANSI: 0 CCS
Feb 9 14:17:30 localhost kernel: [ 1526.239706] sd 5:0:0:0: Attached scsi generic sg1 type 0
Feb 9 14:17:30 localhost kernel: sd 5:0:0:0: Attached scsi generic sg1 type 0
Feb 9 14:17:31 localhost kernel: [ 1527.483293] sd 5:0:0:0: [sdb] 60978816 512-byte logical blocks: (31.2 GB/29.0 GiB)
Feb 9 14:17:31 localhost kernel: [ 1527.484077] sd 5:0:0:0: [sdb] Write Protect is off
Feb 9 14:17:31 localhost kernel: sd 5:0:0:0: [sdb] 60978816 512-byte logical blocks: (31.2 GB/29.0 GiB)
Feb 9 14:17:31 localhost kernel: sd 5:0:0:0: [sdb] Write Protect is off
Feb 9 14:17:31 localhost kernel: [ 1527.490803] sd 5:0:0:0: [sdb] No Caching mode page found
Feb 9 14:17:31 localhost kernel: [ 1527.490819] sd 5:0:0:0: [sdb] Assuming drive cache: write through
Feb 9 14:17:31 localhost kernel: sd 5:0:0:0: [sdb] No Caching mode page found
Feb 9 14:17:31 localhost kernel: sd 5:0:0:0: [sdb] Assuming drive cache: write through
Feb 9 14:17:31 localhost kernel: [ 1527.523114] sdb: sdb1
Feb 9 14:17:31 localhost kernel: sdb: sdb1
Feb 9 14:17:31 localhost kernel: [ 1527.527022] sd 5:0:0:0: [sdb] Attached SCSI removable disk
Feb 9 14:17:31 localhost kernel: sd 5:0:0:0: [sdb] Attached SCSI removable disk
Feb 9 14:17:31 localhost kernel: [ 1527.572495] sd 5:0:0:0: [sdb]
Feb 9 14:17:31 localhost kernel: [ 1527.572510] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Feb 9 14:17:31 localhost kernel: [ 1527.572516] sd 5:0:0:0: [sdb]
Feb 9 14:17:31 localhost kernel: [ 1527.572521] Sense Key : Medium Error [current]
Feb 9 14:17:31 localhost kernel: [ 1527.572529] sd 5:0:0:0: [sdb]
Feb 9 14:17:31 localhost kernel: [ 1527.572535] Add. Sense: Unrecovered read error
Feb 9 14:17:31 localhost kernel: [ 1527.572540] sd 5:0:0:0: [sdb] CDB:
Feb 9 14:17:31 localhost kernel: [ 1527.572543] Read(10): 28 00 03 a2 76 00 00 00 08 00
Feb 9 14:17:31 localhost kernel: [ 1527.572559] end_request: critical medium error, dev sdb, sector 60978688
Feb 9 14:17:31 localhost kernel: [ 1527.572569] Buffer I/O error on device sdb, logical block 7622336
Feb 9 14:17:31 localhost kernel: Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Feb 9 14:17:31 localhost kernel: Sense Key : Medium Error [current]
Feb 9 14:17:31 localhost kernel: Add. Sense: Unrecovered read error
Feb 9 14:17:31 localhost kernel: sd 5:0:0:0: [sdb] CDB:
Feb 9 14:17:31 localhost kernel: [ 1527.580110] sd 5:0:0:0: [sdb]
Feb 9 14:17:31 localhost kernel: [ 1527.580122] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Feb 9 14:17:31 localhost kernel: [ 1527.580126] sd 5:0:0:0: [sdb]
Feb 9 14:17:31 localhost kernel: [ 1527.580130] Sense Key : Not Ready [current]
Feb 9 14:17:31 localhost kernel: [ 1527.580137] sd 5:0:0:0: [sdb]
Feb 9 14:17:31 localhost kernel: [ 1527.580144] Add. Sense: Medium not present
Feb 9 14:17:31 localhost kernel: [ 1527.580148] sd 5:0:0:0: [sdb] CDB:
Feb 9 14:17:31 localhost kernel: [ 1527.580151] Read(10): 28 00 03 a2 76 00 00 00 08 00
Feb 9 14:17:31 localhost kernel: [ 1527.580164] end_request: I/O error, dev sdb, sector 60978688
Feb 9 14:17:31 localhost kernel: [ 1527.580172] Buffer I/O error on device sdb, logical block 7622336
Feb 9 14:17:31 localhost kernel: Read(10): 28 00 03 a2 76 00 00 00 08 00
Feb 9 14:17:31 localhost kernel: end_request: critical medium error, dev sdb, sector 60978688
Feb 9 14:17:31 localhost kernel: Buffer I/O error on device sdb, logical block 7622336
Feb 9 14:17:31 localhost kernel: Sense Key : Not Ready [current]
Feb 9 14:17:31 localhost kernel: Add. Sense: Medium not present
Feb 9 14:17:31 localhost kernel: end_request: I/O error, dev sdb, sector 60978688
Feb 9 14:17:31 localhost kernel: [ 1527.600643] sdb: detected capacity change from 31221153792 to 0
Feb 9 14:17:31 localhost kernel: sdb: detected capacity change from 31221153792 to 0
Feb 9 14:17:32 localhost systemd-udevd: error: /dev/sdb1: No such file or directory
Feb 9 14:17:32 localhost systemd-udevd: inotify_add_watch(7, /dev/sdb1, 10) failed: No such file or directory
Feb 9 14:17:32 localhost systemd-udevd: error: /dev/sdb: No medium found
