Blue_Alien wrote:The cable is a waterproof, 20 conductor, and about 150ft long. It works with my desktop but not with the pi. Maybe the signal is too low for the pi to handle? Maybe adding a signal booster will allow the pi to connect.
You desktop and RasPis have slightly different magnetics (Ethernet connector), so some combinations work where the mentioned falls out of accepted ranges. Adding a signal booster might help, but not necessarily because of the signal boosting.
I don't think that you can get exact answer in the forum(s), from miles away... we can only guess. If you'd like to get proper answer (to be sure that the communication would also work reliably on the field), a network cabling/signals analyzer would help. It could point to the source of the problem and you'd also be able to verify that a modification afterwards shifts states deeply into area aligned with specifications.
Best wishes, Ivan Zilic.
