If you've never seen "even a hint of" green led ACtivity then the only other thing I can think of that you haven't mentioned is a visual inspection of the SD card socket. Is the card going full home and activating the card detect switch? Are there any bent or flattened pins? Although there have been no reports for quite some time, there have been mechanical failures of the socket** in the past and also "contact failure" due to cards "bowing" or being "misaligned" by pressure from "case slots" etc.fmcpeek wrote:I have just a red light glowing. I have read and tried the boot sticky, tested my voltage and the fuse and all appears fine, I have sd formatted and tried 2 different mem cards (8gb and a 16gb), written the noobs files to the mem card, used dd and put a raspbian image on both cards, used tried it with and without usb kb and mouse connected, with and without ethernet connection, replaced ethernet cord, Win32diskimager to write those image files (looked fine when later viewed), tried a different SD writer, tried it with and without HDMI, tried 2 different monitors. My question is..Is my unit dead? Not one thing that I have tried has changed it in any way that I can tell. Are there any other options or is my Pi dead?
***Update***** The SD CARD was NOT seated correctly. I had to 'force' a piece of 'business card' stock size paper in the socket to keep the SD CARD seated and (terminal connection) in place. This is the only "long term" fix I could think of.yardie2856 wrote:I am having a similar problem.. I purchased my card a year and a half ago; and today it just stop working. I can no longer boot it. Followed all instructions above, all I get is a SOLID RED LIGHT (Power only). I do have a 'very faint' GREEN LIGHT.
