janob
RPi don't boot when HDMI is connected
Tue Apr 08, 2014 7:24 am
I have a problem - if nothing is connected (no HDMI, no composite, no audio, no ethernet, power only), LED blinks like booting is in process. BUT if I connect HDMI cable, LED stops blinking - red one is lighting only. It was working some days before, but suddenly it stops.
The same power supply with the same SD card works with another piece of RPi. I tried another more powerfull power supply already (2A), but the same result ...
Is my RPi defective? Can I test it somehow else?
FTrevorGowen
Re: RPi don't boot when HDMI is connected
Tue Apr 08, 2014 11:11 am
janob wrote:I have a problem - if nothing is connected (no HDMI, no composite, no audio, no ethernet, power only), LED blinks like booting is in process. BUT if I connect HDMI cable, LED stops blinking - red one is lighting only. It was working some days before, but suddenly it stops.
What is your HDMI cable connected to?
Which O.S. are you using? Did you use NOOBS to install it?
To confirm your "PSU swap test" can you measure the voltage between testpoints TP1 & TP2 (as marked on the pcb) with and without the cable present. Also try a different cable if you can and/or without anything on "the other end".
Trev.
janob
Wed Apr 09, 2014 12:20 pm
FTrevorGowen wrote:[quote=
Trev.
As I said already - the same HDMI cable with the same SD card and the same power supply works with another RPi (and the same Panasonic plasma TV). It worked before too, but suddenly it doesn't. Tested with another HDMI cable with the same result.
OS - raspbmc (the same result with Raspbian, NOOBS not tested)
I will try to measure voltage between TP1 and TP2 when I am at home.
Jan
Genius23008
Fri Apr 11, 2014 12:50 pm
Enable the safe mode in the configuration settings, I haven't had this issue but had something remotely like it. Safe mode fixed it for me.
