Leo Rest
More of a base than a case
Sun Jun 03, 2012 8:21 pm
A simple idea to protect my slice of pi. I haven't seen this posted before so I thought I would share it with you...
OK so I failed to upload the image so a description will have to do for now.
The base plate is a scrap CD disk with holes drilled in. Three plastic standoffs support the pcb by trapping each edge under a nut. Careful positioning of the supports ensures that components and tracks are kept safe.
The pi is supported raised off the ground safe from being shorted out.
If I manage to work out why my image wouldn't upload I'll put the picture up.
gruso
Re: More of a base than a case
Mon Jun 04, 2012 12:21 am
Sounds very much like the method I just posted in this thread: http://www.raspberrypi.org/phpBB3/viewt ... =40&t=7330
My standoffs are metal, so I'm using some plastic washers as well.
Leo Rest
Mon Jun 04, 2012 3:50 am
gruso wrote:Sounds very much like the method I just posted in this thread: http://www.raspberrypi.org/phpBB3/viewt ... =40&t=7330
That's exactly what I was trying to describe - thanks.
I don't know why my image wouldn't upload maybe there is,a resolution limit?
Leo Rest
Tue Jun 05, 2012 3:04 pm
Leo Rest wrote:...I don't know why my image wouldn't upload maybe there is,a resolution limit?
...or maybe there is a block on uploads for the first three posts. Hurry up mods and release this post into the wild so I can share my image please.
stevepdp
Tue Jun 05, 2012 3:31 pm
New users must wait for three post approvals before they are given the usual posting rights on this forum.
Could you please try again when your post count is >= 3? If it continues to be a problem for you then I'll raise the issue with the admins.
Leo Rest
Tue Jun 05, 2012 5:14 pm
stevepdp wrote:...Could you please try again when your post count is >= 3? If it continues to be a problem for you then I'll raise the issue with the admins.
Thanks Steve. My last post was #3 so the next one is the acid test!
Leo Rest
Tue Jun 05, 2012 6:04 pm
Still having trouble uploading an image. I dropped the resolution down each attempt. At the moment when I attempt to upload it errors saying invalid image. It's a 640x368 jpeg
129KB taken on and sent from an HTC one running Android ICS so I doubt the image format is the issue.
gruso
Wed Jun 06, 2012 3:57 am
Just upload your pics somewhere else, like http://imgur.com/ :-)
Once uploaded, grab the BB code and paste it here. It will look something like this:
[img.]http://i.imgur.com/ZHMVl.png[/img]
