sudo /sbin/rebootI have also now tried ssh'ing in and running a reboot. It shuts down but doesn't come back up.
Anyone know what could be causing this? Its been running fine for ages. I also do weekly updates - could that have caused a problem?
Here are the last few lines of the messages on the reboot.
Apr 5 05:07:29 weather kernel: [ 8.160795] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5390, rev 0502 detected
Apr 5 05:07:29 weather kernel: [ 8.269152] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5370 detected
Apr 5 05:07:29 weather kernel: [ 8.306674] usb_audio: Warning! Unlikely big volume range (=6144), cval->res is probably wrong.
Apr 5 05:07:29 weather kernel: [ 8.368587] usb_audio: [5] FU [Mic Capture Volume] ch = 1, val = 1536/7680/1<6>[ 8.424274] usbcore: registered new interface driver snd-usb-audio
Apr 5 05:07:29 weather kernel: [ 9.030728] usbcore: registered new interface driver rt2800usb
Apr 5 05:07:29 weather kernel: [ 20.429099] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
Apr 5 05:07:29 weather kernel: [ 20.936484] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
Apr 5 05:07:29 weather kernel: [ 21.758309] i2c /dev entries driver
Apr 5 05:07:29 weather kernel: [ 27.390699] FAT-fs (mmcblk0p5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Apr 5 05:07:29 weather kernel: [ 30.284573] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
Apr 5 05:07:29 weather kernel: [ 30.291697] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
Apr 5 05:07:29 weather kernel: [ 30.916390] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
Apr 5 05:07:29 weather kernel: [ 34.124581] wlan0: authenticate with f4:ec:38:d0:a1:5e
Apr 5 05:07:29 weather kernel: [ 34.177119] wlan0: send auth to f4:ec:38:d0:a1:5e (try 1/3)
Apr 5 05:07:29 weather kernel: [ 34.178864] wlan0: authenticated
Apr 5 05:07:29 weather kernel: [ 34.180105] rt2800usb 1-1.2.3:1.0 wlan0: disabling HT as WMM/QoS is not supported by the AP
Apr 5 05:07:29 weather kernel: [ 34.180145] rt2800usb 1-1.2.3:1.0 wlan0: disabling VHT as WMM/QoS is not supported by the AP
Apr 5 05:07:29 weather kernel: [ 34.189558] wlan0: associate with f4:ec:38:d0:a1:5e (try 1/3)
Apr 5 05:07:29 weather kernel: [ 34.191982] wlan0: RX AssocResp from f4:ec:38:d0:a1:5e (capab=0x431 status=0 aid=30)
Apr 5 05:07:29 weather kernel: [ 34.207697] wlan0: associated
Apr 5 05:07:29 weather kernel: [ 34.331820] bcm2835-cpufreq: switching to governor ondemand
Apr 5 05:07:29 weather kernel: [ 34.331852] bcm2835-cpufreq: switching to governor ondemand
Apr 5 05:07:30 weather kernel: [ 37.108492] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
