Ilans wrote:Yes
What Should I choose in that menu ?
Ilan
the options in there are configurations that different people will want differently. Be sure to update the Localisation options for your local region. Also look through all of the others to determine how you want those set. Defaults are usually okay if you're not sure, but any that you want changed, go ahead and change them. If you do something now and change your mind, it's not a problem. Just issue the command again and change the option later.
Also, you'll want to bring your software and firmware up to date. Issue the following three commands, in this order. (Some of them take quite a while, and you need Internet access.)
sudo apt-get update
sudo apt-get upgrade
sudo rpi-update
