meddyliol
Fuzzy display
Thu Mar 27, 2014 10:31 am
I have just booted the Raspi up for the first time. Had no problems except that the display icons are a little fuzzy. It is connected to a small TV via the HDMI cable and is at 1080. I have looked for a setting to change it but cannot find anything. I have never had a problem with this TV before and it is frequently used with a PS3 game machine. Any help would be appreciated.
Brian :?
Raspberry Pi B, Raspberry Pi 2, monitor, powered hub, mouse, keyboard and Volvo V50 car
elatllat
Re: Fuzzy display
Sun Mar 30, 2014 2:24 pm
what is the model # of the TV?
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
meddyliol
Re: Fuzzy display
Sun Mar 30, 2014 2:50 pm
Logik L19DVDB20(A)
elatllat
Re: Fuzzy display
Sun Mar 30, 2014 7:40 pm
According to the manual:
http://documents.knowhow.com/TV-Home%20 ... DVDP10.pdf
you are a 720p TV, so google how to tell the rpi to use 720p instead of 1080p.
meddyliol
Re: Fuzzy display
Mon Mar 31, 2014 7:23 am
Thanks for that. I will have a look around. :)
GTR2Fan
Re: Fuzzy display
Mon Mar 31, 2014 7:39 am
It's sold as a 720p TV but, as always seems to be the case, it isn't one.
According to page 55 of the manual it's a 1366x768 panel, yet according to page 54 it doesn't support this as an input resolution. You're never going to get a pin-sharp image out of it whatever you do as everything will always be rescaled. The best you'll ever achieve is a compromise I'm afraid.
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
meddyliol
Re: Fuzzy display
Mon Mar 31, 2014 9:20 am
Thanks for your input (no pun intended). I might get it connected to a 'proper' monitor.
