PalashTaneja
Problem with SD Card
Sat Mar 22, 2014 11:42 am
Hi friends,
I have a Model B raspberry pi, until yesterday I was using a Lexar 4 GB SDHC Card with Raspbian installed via NOOBS and I suppose that the card got corrupted and I had to do an of install Raspbian again but the pi refuses to boot up with the card with NOOBS zip contents in it. I had also created a .img backup of the card using Win32DiskImager and it didn't boot even with that.
I can confirm that the pi doesn't boot because the light on my wireless keyboard receiver doesn't light up. Also I cannot see any green light.
Hoping for Help :cry:
GTR2Fan
Re: Problem with SD Card
Sat Mar 22, 2014 11:47 am
Did you format the SD card before trying again with the recommended SD card formatter as described on the official NOOBS download page?
http://www.raspberrypi.org/downloads
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
PalashTaneja
Mon Mar 24, 2014 4:30 am
GTR2Fan wrote:Did you format the SD card before trying again with the recommended SD card formatter as described on the official NOOBS download page?
Ya pretty sure of that I used Format size adjustment On and Quick Format
FTrevorGowen
Mon Mar 24, 2014 9:20 am
Full (Overwrite) Format + Format Size Adjustment On may be better**
Trev
** see:
http://www.cpmspectrepi.webspace.virgin ... 121XP.html etc.
hexameron
Mon Mar 24, 2014 11:50 am
I have a similar problem. After two years with no sd-card corruption I got a Sony 4Gb card. This worked well for a month, then got corrupted. Except that it is not always corrupt - on ubuntu it will FSCK clean, and it continues to boot on my model A, but my model Bs cannot load (any) start.elf
Must be a power supply problem...
kyle2k
Mon Mar 24, 2014 1:34 pm
Not sure if this is related to your problem or not but on the downloads page it does state that you now need an 8GB (or larger) SD card for a NOOBS installation.
PalashTaneja
Tue Mar 25, 2014 5:38 am
kyle2k wrote:Hi,
Sorry bro, but the quick start pdf shows that we need a 4 Gb or larger card.
PalashTaneja
Tue Mar 25, 2014 5:42 am
hexameron wrote:I have a similar problem. After two years with no sd-card corruption I got a Sony 4Gb card. This worked well for a month, then got corrupted. Except that it is not always corrupt - on ubuntu it will FSCK clean, and it continues to boot on my model A, but my model Bs cannot load (any) start.elf
I will try to use a different power adapter.
FTrevorGowen
Tue Mar 25, 2014 8:04 am
PalashTaneja wrote:
kyle2k wrote:Hi,
Both of you are "correct" - the info. on the downloads page (but probably not in the quick start guide) was changed because if you use NOOBS full to install Raspbian** it may not fit on some 4Gb cards, giving rise to problems for some users. Most, if not all, of the other O.S.'s will fit on a 4Gb card and it should be possible to install Raspbian on a 4Gb card with NOOBS lite which downloads Raspbian only (NOOBS full includes compressed images of several O.S.'s).
Trev.
** Which has "grown" somewhat since the main NOOBS docs. were written.
hexameron
Wed Mar 26, 2014 1:53 pm
... cunning plan #1: replace the regulator on my first Model B, Dave Akerman style. Result: so far so good - card now boots on the Pi with new regulator, still fails on my other Model B.
