jcanion
SD Card error (Advise)
Sat Mar 22, 2014 5:53 am
Aloha
Please advise
The board boot up than hangs:
on the Command Line:
[ 2.574478] [<c04.....
PANIC :VFS: Unable to mount root fs on unknown block(179,5)
Entering kdb (current-)xdaB2ac80, pid 1) due to Keyboard Entry
At the above line the board hangs, mouse/KB are disabled
Attached error (magnify to view) thx
Re: SD Card error (Advise)
Sat Mar 22, 2014 8:21 am
You need to rebuild your SDCard. The ext4 rootfs is unreadable.
jcanion
Sat Mar 22, 2014 4:51 pm
DougieLawson wrote:You need to rebuild your SDCard. The ext4 rootfs is unreadable.
Thanks you Dougie
Not sure "how" to rebuild the SDCard
I tried to reformat several times using the SD Formatter but same results?
Is there a tutorial?
I am running Windows
GTR2Fan
Sat Mar 22, 2014 4:57 pm
When you used SDFormatter, did you remember to set the format size adjustment option to 'ON'?
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
DeeJay
Sat Mar 22, 2014 5:11 pm
jcanion wrote: Not sure "how" to rebuild the SDCard
Read the Quick Start Guide which is linked from the Downloads Page on the http://www.raspberrypi.org website.
SDFormatter gives you a clean/blank card. You then need to re-instate the NOOBS installer.
