mladic97
Short Circuit
Fri Mar 21, 2014 3:13 pm
I tryied to connect a fan to the raspberry. When I did this, I accidentally connected the 2 pins in the first row and I'm pretty sure I maked a short circuit, even the power button flashed brighter then I connected them. Now only the power button is on when I connect to the power. Is my raspberry dead for sure?
Joe Schmoe
Re: Short Circuit
Fri Mar 21, 2014 3:18 pm
For the answer to this question, see the "What I have learned" thread.
gordon77
Re: Short Circuit
Fri Mar 21, 2014 3:19 pm
I assume you mean you connected the 3.3v to 5v, so probably :(
GTR2Fan
Re: Short Circuit
Fri Mar 21, 2014 3:36 pm
Which two pins?
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
mladic97
Re: Short Circuit
Fri Mar 21, 2014 3:40 pm
GTR2Fan wrote:Which two pins?
What is bottom what is top?
mladic97
Re: Short Circuit
Fri Mar 21, 2014 3:41 pm
The first row next to the memory card. And the second row too.
GTR2Fan
Re: Short Circuit
Fri Mar 21, 2014 3:44 pm
This is looking down from the top with the SD card socket nearest you.
EDIT: That does sound like the 3V3 and 5V pins then. Sorry, but it's most likely fried IMO. :(
klricks
Re: Short Circuit
Fri Mar 21, 2014 5:23 pm
For reference find the P1 printed on the board or find the pin with the square solder pad. That is pin 1 (3V3).
RaTTuS
Contact: Twitter YouTube
Re: Short Circuit
Fri Mar 21, 2014 5:29 pm
1) you don't need a fan
2) use jumpers
3) don't connect +3.3V to +5V
4) you don't need a fan
5) you will burn out your GPIO pins if you draw too much power
6) yes you have probably made a brick
p.s. did I mention
Covfefe
