Fri Mar 21, 2014 11:07 am
francescojordan wrote:HI! thanks for the reply.
i think i expressed myself badly..
When the Pi doesn't boot i remove the cable...the if it boot there's no problem and it don't tell me that i shutdown incorretly...
O.K., but exactly how do you shutdown? (The Pi will not tell you whether you've shutdown correctly or not).
However, if you're using the Raspbian desktop the "red button" on the desktop will perform a clean shutdown for you (the one on the taskbar just takes you out of the desktop to the "command-line" and from there you have to issue the shutdown command manually, like in my previous post)
Trev.
