If anyone can decode my blurb I could do with some advice.
Brian
Using SDFormatter is redundant/superfluous if you plan to 'flash' an Operating system image file onto the SD card. But no harm has been done.meddyliol wrote:How do I go about imaging the SD card? I have formatted the card with the recommended formatter (SDFormatter). Now what do I do?
The following raw images are intended for advanced users. To use an image file, you will need to unzip it and write it to a suitable (2GB or larger, 4GB or larger for Raspbian) SD card using the UNIX tool dd. Windows users should use Win32DiskImager. Do not try to drag and drop or otherwise copy over the image without using dd or Win32DiskImager – it won’t work. If you’re still not clear on what to do, the community on the Raspberry Pi Wiki has written a guide for beginners on how to set up your SD card.
