The only thing i found :
http://robotblogging.blogspot.de/2013/1 ... ng-on.html
Check the comments , especially those from Dom.
If this isn't useful for you , i guess your only remaining option is
to write custom GPU assembly , which will be very complicated.
First :
http://www.broadcom.com/support/
Check both links under "VideoCore Graphics Resources"
Second :
www.github.com/hermanhermitage/videocoreiv
Lots of information , code , and links (mostly based on
reverse engineering).
Look at all the resources and see for yourself which approach
makes the most sense for your application.
ghans
