this is a possibility even I thought of... but taking into consideration the overall environment remains constant ( the image is taken of a monochromator itself (can be considered as a constant light source at a particular wavelength) in aclosed chamber) other than noise... should software cause a problem to the repeatability??? or it is the hardware gain control and exposure control causing the problem???jamesh wrote:Probably a slight oscillation on the AWB or AGC. We are looking in to ways of 'locking' it but at the moment, constant light sources are probably the best option.
