todbanner
Fast User Switching
Tue Mar 18, 2014 5:04 pm
I've just replaced the windows 7 pc in our family room with a RPi.
All the family members had their own log in to the windows 7 machine which kept their profiles, documents, etc. We all know how multi-users on a system work.
When I needed to move the windows 7 machine elsewhere I thought the RPi was an obvious replacement as this workstation gets used for facebook / gmail and other web browsing, nothing the RPi can't handle.
I got it all hooked up yesterday and came to find it appears that "fast user switching" isn't built into Raspbian.
I've done some googling around and come up with nothing, I wondered if I was missing something obvious and if the RPi community could help?
What do we think people?
GTR2Fan
Re: Fast User Switching
Tue Mar 18, 2014 5:09 pm
I'm a relative noob myself, but a quick Google search threw up this...
http://sourcearchive.raspbian.org/main/ ... ch-applet/
...so maybe it's in there somewhere already if we know where to look? :)
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
klricks
Tue Mar 18, 2014 5:17 pm
Not sure about fast switching but this will allow different users to log into/out of GUI.
sudo leafpad /etc/lightdm/lightdm.conf
Find this line: (approximately line 78 in file)
autologin-user=pi
Comment out this line by inserting a # like this:
#autologin-user=pi
save and reboot.
todbanner
Tue Mar 18, 2014 5:45 pm
GTR2Fan wrote:I'm a relative noob myself, but a quick Google search threw up this...
Wow... perhaps google had a headache yesterday when I was searching.
That seems like it would be exactly what I need from the description!
I'll let you know how it goes. Thanks!
todbanner
Tue Mar 18, 2014 5:55 pm
klricks wrote:Not sure about fast switching but this will allow different users to log into/out of GUI.
autologin-user=pi
#autologin-user=pi
save and reboot.
Great, that might work too if the fast switching app doesn't.
I'm not going to get to playing with this until the evening today. But I will do as a good forum user should and report back :)
todbanner
Mon Mar 24, 2014 2:18 am
A couple of updates:
Solution 2: Comment line from /etc/lightdm/lightdm.conf
My line is already commented. When I select log out on the bottom right power button, I get sent back to the console. I can then run startx to get back to x. It does not offer me a user option.
Solution 1: fast-switch/fast-user-switch-applet-2.24.0
I'm stuck on ./configure. I fought with dependencies for a while the other night. Gave up and have only just come back to it. Currently I'm at:
checking pkg-config is at least version 0.9.0... yes
checking for APPLET... configure: error: Package requirements (gtk+-2.0 >= 2.8.0
	     libpanelapplet-2.0 >= 2.0.0
	     libglade-2.0 >= 2.0.0
	     gio-2.0 >= 2.15.3) were not met:
No package 'libpanelapplet-2.0' found
No package 'libglade-2.0' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables APPLET_CFLAGS
and APPLET_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
I'm going to go away and read about libpanelapplet-2.0 and see if it can be installed into raspbian. It doesn't appear to be available from stock sources.
Am I missing anything completely n00b and obvious?
Cheers.
klricks
Mon Mar 24, 2014 2:44 am
todbanner wrote:A couple of updates:
Sorry in order for the GUI login to work correctly you must first enable boot to desktop using:
sudo raspi-config
THEN reboot the system
THEN edit the lightdm file.
Must be done in that order.
Note that raspi-config will take out the comment # in lightdm so you have to put the # back after booting into the GUI the first time only.
Tarcas
Mon Mar 24, 2014 3:41 am
Sorry if you've already done this, but since nobody has mentioned it I thought I should check... You have created the various user accounts, right? If not, the command is "adduser [username]" and it'll walk you through the rest.
On a related note, if there's anything that you want each user to have in their ~/ directory when the account is created (such as files on their desktop, a custom .bashrc, public_html folder, etc) you can put it in /etc/skel/ before creating the users. Everything in that directory will be copied into every subsequently created user's home directory. Extremely handy when creating lots of accounts with similar purposes.
Return to “Beginners”
