I've been running RaspBMC 24/7-ish for just over a month now on the custom overclock settings in my forum signature with no sign of issues so far. I realise that this falls short of your several months, but temperatures are only slightly higher than on stock clocks here and are always at least 25°C below the recommended maximum of 85°C with an ambient room temperature of around 20°C.gpharos wrote:I am loading these device with Raspbmc and using them as front ends to my xbmc server. I just now ordered a pack of 8 heat sinks to add to the warranty replacements, I had both units set for fast according to the Raspbmc settings.
That's what I am looking for, a reliable low cost solution. I currently have 2 PI's working now, and another one coming as a warranty replacement. @ GTR2Fan when I ck temps on the working ones at idle they are running around 57-60C and under load stay in the 60C mark. The last one to go, I had moved some folders around on the server and added new movies. While it was cleaning the lib (it stalled around half way trhough for 3-5 minuites due to the cahnges I made) and once it reached the 100% mark it just froze. After power off it never came back up, tv just posts no hdmi 2 input is attached and no boot Splash. Changed power supply and sd card from a working one with no success. I am just concerned that maybe PI's built say in the UK are better quality than ones from China.iinnovations wrote:No. I have been running a dozen Pis for a year or two with no failures except one due to operator error.
I hope not. Mine's a Model B Rev1, possibly Chinese? Thankfully it was a present from a very good friend.gpharos wrote:I am just concerned that maybe PI's built say in the UK are better quality than ones from China.
Do you have any information on what actually failed on the Pi's? It would be exceptional unusual for you to have two failures, so knowing exactly what went wrong with them would be a good start to figuring out the problem.gpharos wrote:I have bought two PI's from a qualified distributor. The purchase was made on November 13, 2013 and since then both PI's have failed. The first one within a month and just recently the second one. They honored the warranty, but my concern is the quality of the product. I am loading these device with Raspbmc and using them as front ends to my xbmc server. I just now ordered a pack of 8 heat sinks to add to the warranty replacements, I had both units set for fast according to the Raspbmc settings. I have the replacement set for default, but I think it must be a heat issue or quality of the parts. Has anyone else had problems with these going out over a period of months?
Stopped working, no boot Splash screen, dead in the water with pwr light lit on the PI. Sitting here looking at the one I requested an RMA on there is a power light on the PI but no pwr light on an attached four port passive usb hub nor a usb attached Kybd. Looks to be a power problem. The first one popped up a D-BUS error and was non responsive while accessing xbmc menus on tv, reset pwr and unit was non responsive.gkreidl wrote:@gpharos: what do you mean by "failed"?
If you are using an unpowered hub, my guess would be you have overloaded the USB polyfuses. The USB on the Raspi is only rated for 100mA IIRC, so any more than that and you need a powered hub. They can take a couple of days (!!) to recover. Check the voltage as suggested above to ensure the Pi is getting enough power.gpharos wrote:Stopped working, no boot Splash screen, dead in the water with pwr light lit on the PI. Sitting here looking at the one I requested an RMA on there is a power light on the PI but no pwr light on an attached four port passive usb hub nor a usb attached Kybd. Looks to be a power problem. The first one popped up a D-BUS error and was non responsive while accessing xbmc menus on tv, reset pwr and unit was non responsive.gkreidl wrote:@gpharos: what do you mean by "failed"?
@Redhawk
" Well you must be doing something wrong, my Pi including the same memory card has been running near sold for 2 years."
Yes I agree that it is strange, but having a initial product release running for 2 years when the first batches were given 100% QC before being released out the door is a little different when a mature product which is tested at maybe 1-2% QC of production units. Plus you need to take into account that manufacturers will change components that supposedly have same specifications (generic) to the original components to reduce manf costs. and increase profit margins. There could be many reasons, just asking if anyone else has had issues with current PI's on the marketplace. Not knocking the product, just curious why I am having these issues.
they did not tell you that, instead you said:gpharos wrote: Not telling me attaching a 4 port usb is bad (works extremely well and usb 2.0 compliant device I own, about 30).
the key word is passive, which means it derives its power from the host (the PI), which on a PI is indeed a bad idea! you need a powered hub! The PI is not designed to power externally powered passive hubs, it has only a few hundred mA reserved for 2 USB devices, but a passive hub with multiple USB devices attached might need 500mA instead which may be too much! It may eventually blow its polyfuse when you try to do that! And in this case it probably did.on an attached four port passive usb hub
Can I ask you to be polite please. I do not like the use of the word fanboy - I regard as insulting, so please don't use it. You are posting on a public forum, and are bound to get a variety of answers, some to questions you haven't asked, but in general the people here know an awful lot, quite likely more than you and anywhere else on the internet, so please calm down. Having read the above, there doesn't seem anything you need to be riled about - it all seems perfectly valid diagnostic advice by people trying to help you. If you don't want help, that's fine, but don't go off on one about it.gpharos wrote:I do not need you fan boys answering questions that are of no help. I bought two PI's at one time from the same distributor. Both serial numbers within a few numbers. I was looking to see if anyone in the Nov/Dec time frame had any pre-mature failures. Not telling me attaching a 4 port usb is bad (works extremely well and usb 2.0 compliant device I own, about 30). The PI has it's own separate pwr supply with 2000mw output power. I connect the four port hub up so I can connect a 1TB external Powered (for you) so I have enough ports for keyboard and MCE receiver. Once programmed and tested for a few days it is attached to my TV's with one MCE receiver and hardwired to a gigabit network. I shouldn't have to come in here to get bashed by ppl who think they know everything and asking/answering questions that are not what I posted. Read the post by me and quit asking questions that have already been answered. The mod can close this thread, I will look elsewhere.
If you're going to answer any questions, at least provide the answer to this one:gpharos wrote:The PI has it's own separate pwr supply with 2000mw output power. I connect the four port hub up so I can connect a 1TB external Powered (for you) so I have enough ports for keyboard and MCE receiver.
jdb wrote:What is the TP1-TP2 voltage on the Pi when it is plugged into the same power supply that the "failed" Pi used?
