jomoto10
wireless charging mats
Sun Mar 16, 2014 8:55 pm
I have seen wireless charging mats before, and was thinking how cool it would be if we could just toss our raspberry pi onto a desk to turn it on. Bluetooth mouse and keyboard, and the only cable you would need would be HDMI. Anyone else think that a completely wireless desktop would be cool?
Douglas6
Re: wireless charging mats
Sun Mar 16, 2014 9:06 pm
jomoto10 wrote:Anyone else think that a completely wireless desktop would be cool?
I do, and I have a set of these inductive charging coils from Adafruit in my toy box, but haven't got around to playing with them. They might prove a little underpowered...
jomoto10
Mon Mar 17, 2014 1:37 am
That's cool! You should PM me if you ever get it working. :D
dan3008
Mon Mar 17, 2014 8:12 am
what kind of voltage/current do you get out of the other end? sounds like fun to me...
dan3008 wrote:Pays your money, takes your choice
klricks
Mon Mar 17, 2014 1:14 pm
dan3008 wrote:what kind of voltage/current do you get out of the other end? sounds like fun to me...
Referring to the Adafruit coils:
The description says 5V 500mA max. Barely enough to run a model B 'headless'
Although the concept seems interesting, It would be cumbersome to implement for a RPi.
- The primary coil needs a 9-12V power supply connected at all times.
- The 2 coils need to be perfectly aligned at all times.... taped together... any slight movement and the RPi will likely crash.
Douglas6
Mon Mar 17, 2014 1:38 pm
My plan is to run the Pi on a LiPo, with the secondary connected to an on-board charger. And then a stand for the primary that will position the Pi to align the coils. I did some tests with two layers of 1mm acrylic between the coils, and I think it just might work. Better for a Model A, it just might discharge more slowly than it charges, but the use case is really for overnight charging, like my phone. I readily admit it's more fun than practical (might as well use pogo pins, since alignment is critical anyways).
jomoto10
Mon Mar 17, 2014 7:29 pm
Not sure if it would work, but couldn't you also use a set of magnets to align the coils? That way if they get separated the should just magnetise back in place.
ruphert
Tue Mar 18, 2014 9:46 am
I know that inductive charging works in mobile but I'm not quite sure if it will work in desktop.
Return to “Off topic discussion”
