DTM450
Analog signal to DAC
Sun Mar 16, 2014 4:18 am
Hi
Not sure if this is the right forum but
I was curious as to what happens to an analog signal when it goes to a Digital to Analog Converter
does the converter leave the signal and is through put or what
Any and all help would be awesome
Raspberry Pi Model B Rev 2
ame
Re: Analog signal to DAC
Sun Mar 16, 2014 6:27 am
DTM450 wrote:Hi
Firstly, you need to clarify your meaning. As written, your message is confusing.
You would not connect an analog signal to a Digital to Analog Converter (DAC).
If you meant Analog to Digital Converter (ADC) then it makes more sense.
As to what happens to the signal, it depends on the circuit design. ADCs usually have a high input impedance, so not much happens to the analog signal. It could be routed to another part of the circuit and used there.
DTM450
Sun Mar 16, 2014 10:19 am
Sorry about the confusion I should have said 'what happens to a analog signal when it goes through an ADC'
And yes I understand you would not connect an analog signal to an ADC but I was curious as to what would happen to the signal
So then with a digital signal going through a DAC nothing happens either
GTR2Fan
Sun Mar 16, 2014 10:27 am
DTM450 wrote:So then with a digital signal going through a DAC nothing happens either
It comes out as an analogue representation of the digital binary input value.
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
DTM450
Sun Mar 16, 2014 10:45 am
*sigh* (its getting late) me and my words I meant to say what would happen if an analog signal was sent through a DAC and a digital signal through an ADC
I do understand the functions of ADCs and DACs
GTR2Fan
Sun Mar 16, 2014 10:53 am
The output would be wrong in either of those situations. It won't simply be passed through in its raw state because it's not what the converter expected. Is that what you were asking?
techpaul
Sun Mar 16, 2014 11:21 am
Best you describe what you mean and which way signals are flowing to which parts of a DAC or ADC, as what you are saying does not make sense.
DAC have OUTPUTs of analog signals, it is rare for analog signals to go IN a DAC, no analog signals go through a DAC or ADC.
In some cases an analog signal is connected to VREF of DAC or ADC for special functions. However these days most folks use digital or analog multipliers for those sorts of functions these days.
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
DTM450
Sun Mar 16, 2014 11:23 am
GTR2Fan wrote:The output would be wrong in either of those situations. It won't simply be passed through in its raw state because it's not what the converter expected. Is that what you were asking?
yes sorry if i made it harder to understand than it should have been
DTM450
Sun Mar 16, 2014 11:24 am
techpaul wrote:Best you describe what you mean and which way signals are flowing to which parts of a DAC or ADC, as what you are saying does not make sense.
yes i meant if it went into the converter
techpaul
Sun Mar 16, 2014 11:25 am
In which way draw a diagram, give more detail
DTM450
Sun Mar 16, 2014 11:46 am
ok this is probably the only way i can explain it, what are the resulting signal outputs from these inputs
Sun Mar 16, 2014 11:52 am
Analog in to a DAC won't produce any meaningful output. DAC needs 8 bit data.
A square wave on an ADC should generate a sensible digital output.
techpaul
Sun Mar 16, 2014 12:00 pm
Putting an signal INTO a DAC does NOT get a digital output, you may well BLOW the DAC.
These devices DAC and ADC are ONE direction devices, you cannot change the direction.
Just like you would not expect connecting microphone to headphone/speaker output to chnage the output into an input to an audio device.
That is why there are the two types of devices
  1. DAC to produce analog output from digital input
  2. ADC to produce digital output from analog input
You cannot reverse their direction.
ame
Sun Mar 16, 2014 1:05 pm
DTM450 wrote:Image
Ok, well, the top one makes no sense, but you could input the analog signal into one of the bits of the DAC. As the signal passes the thresholds for logic high and low you would get a one-bit change in the output. If you chose the MSb then you'd get a large-amplitude square wave out for your sine wave in.
The lower image is equally un-useful, but your output would basically switch between 0 when the square-wave input was low, and, say 255, when the square wave input was high (assuming an 8bit converter). There may be intermediate values during the transitions between high and low states, since the transition is not instantaneous, but that's what you'd see.
techpaul
Sun Mar 16, 2014 1:16 pm
DTM450 wrote:Image
The top diagram makes no sense as it is back to front and shows an IN that is an OUT
techpaul
Sun Mar 16, 2014 1:33 pm
Here is some annotated circuit symbols for an 8 bit DAC and 8 bit ADC, I believe still available and datasheets exist for TDA8702 and TDA8703
Please explain on which pins you would connect the analog signal as an INPUT on the DAC what levels, type and frequency it would be
Example circuit symbols for ADC and DAC
DAC-ADC Circuit.gif (9.24 KiB) Viewed 3228 times
DTM450
Sun Mar 16, 2014 9:37 pm
Thanks everyone you have sated my curiosity
