Hi
Not sure if this is the right forum but
I was curious as to what happens to an analog signal when it goes to a Digital to Analog Converter
does the converter leave the signal and is through put or what
Any and all help would be awesome
Firstly, you need to clarify your meaning. As written, your message is confusing.DTM450 wrote:Hi
It comes out as an analogue representation of the digital binary input value.DTM450 wrote:So then with a digital signal going through a DAC nothing happens either
yes sorry if i made it harder to understand than it should have beenGTR2Fan wrote:The output would be wrong in either of those situations. It won't simply be passed through in its raw state because it's not what the converter expected. Is that what you were asking?
yes i meant if it went into the convertertechpaul wrote:Best you describe what you mean and which way signals are flowing to which parts of a DAC or ADC, as what you are saying does not make sense.
DAC have OUTPUTs of analog signals, it is rare for analog signals to go IN a DAC, no analog signals go through a DAC or ADC.
In some cases an analog signal is connected to VREF of DAC or ADC for special functions. However these days most folks use digital or analog multipliers for those sorts of functions these days.
In which way draw a diagram, give more detailDTM450 wrote:yes i meant if it went into the convertertechpaul wrote:Best you describe what you mean and which way signals are flowing to which parts of a DAC or ADC, as what you are saying does not make sense.
Ok, well, the top one makes no sense, but you could input the analog signal into one of the bits of the DAC. As the signal passes the thresholds for logic high and low you would get a one-bit change in the output. If you chose the MSb then you'd get a large-amplitude square wave out for your sine wave in.
The top diagram makes no sense as it is back to front and shows an IN that is an OUT
