Ivan.L wrote:Ok guys.
Yesterday I checked the ic on the display driver. Now I checked the inverter ic and found the datasheet for it.
I found that the two pads on the pcb lead to the ic. One is a power input and the other is chip enable.
The input voltage is from 6V to 17V.
I plan to use it as a screen for th RPI. How many amps my power supply must provide at minimum?
The display driver has 5 pins:DVD/TV,TV/C S_Y,GND and REM.
also the main board has composit input.
What is the brand and model of the DVD player?
Google that and see if you can find a user-manual with specifications for the power supply.
If you have never used the RPi on composite then I would suggest that you try it on another working composite display or TV.
IMO composite is not usable for a main display. ...... Poor quality low resolution and jittery hard to read text.... Some do OK with it though.
