Mamvcivm
Dead HDMI
Wed Mar 12, 2014 7:14 pm
Hello, I once accidentally connected the wrong hdmi lead into my Pi. Instead of the one connected to my TV, I connected the one from my PC. Since then, I get no output from the Hdmi connection. Other than that, the Pi works perfectly, obviously using the s-video output.
I have since bought a second Pi which works perfectly (through hdmi) on the same TV, so I know the problem isn't the tv or the cable.
My question is, is there any way to troubleshoot the hdmi output? Is there any diagnostic software I can run?
Thanks,
Andrew
GTR2Fan
Re: Dead hdmi
Wed Mar 12, 2014 7:43 pm
Mamvcivm wrote:My question is, is there any way to troubleshoot the hdmi output? Is there any diagnostic software I can run?
I don't think it would help much if there was as it all comes straight from pins on the BCM2835. It might be worth checking the protection diodes I guess. That's D14, 15 and 16 on page 2 of the schematic.
http://www.raspberrypi.org/wp-content/u ... .2_027.pdf
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
Methanoid
Re: Dead hdmi
Thu May 07, 2015 6:00 pm
I have a B with apparent dead HDMI (works fine composite). I have tried all the Force HDMI stuff and no joy. I have a digital MM and found this guide which says how to test diodes. http://en-us.fluke.com/training/trainin ... meter.html But (sorry, noob alert) how do I test the Pi diodes which have 3 connections
        OOO
which do I connect the red and black prongs to? and if a diode is the issue, any ideas where I can get identical replacements? I can find a friend who can do the replacement I hope.
Methanoid
Re: Dead hdmi
Tue May 19, 2015 10:02 am
No-one able to help? :(
Burngate
Re: Dead hdmi
Tue May 19, 2015 3:36 pm
Does this help?
From the data sheet https://www.fairchildsemi.com/datasheets/BA/BAV99.pdf
Treat it as two separate diodes.
Methanoid
Re: Dead hdmi
Sun May 24, 2015 5:07 pm
Burngate wrote:Does this help?
Very helpful... but I am still stuck. All diodes seem to work (they all pulse with a number (1400-1800) before dropping to 1.... I assume that means they work?
mahjongg
Re: Dead HDMI
Sun May 24, 2015 9:47 pm
This means they seem to conduct current, but if they have turned into a molten blob of silicon they would conduct current too!
the trick is, if you reverse the polarity of the test leads will they bar the current too?
run any software that should generate a HDMI picture, if no picture appears then HDMI might be broken (what did you expect?)
IMHO you have damaged the HDMI port beyond repair.
