lilzz
Trying to make sense of following code
Mon Mar 10, 2014 7:33 pm
https://code.google.com/p/webiopi/sourc ... _init__.py
class Pressure():
    def __init__(self, altitude=0, external=None):
        self.altitude = toint(altitude)
        if isinstance(external, str):
            self.external = deviceInstance(external)
        else:
            self.external = external
        if self.external != None and not isinstance(self.external, Temperature):
            raise Exception("external must be a Temperature sensor")
    def __family__(self):
        return "Pressure"
    def __getPascal__(self):
        raise NotImplementedError
    def __getPascalAtSea__(self):
    @request("GET", "sensor/pressure/pa")
    @response("%d")
    def getPascal(self):
        return self.__getPascal__()
Last line, self._getPascal__() which is defined as
There's nothing inside the _getPascal__ function. There's real stuff inside. Is this right?
joan
Re: Trying to make sense of following code
Mon Mar 10, 2014 7:52 pm
It looks like a place holder for code which will be implemented but hasn't been so far.
Return to “Python”
