ypkdani
Compatible Keyboard + Mouse wifi
Fri Jun 01, 2012 7:28 am
I have to buy a Keyboard with usb connector for begin to use my Rasp. I'm thinking to buy a kit with keyboard+mouse but i don't know what model could work with debian. Do you have some suggest? Thanks
Alfadaz
Re: Compatible Keyboard + Mouse wifi
Fri Jun 01, 2012 8:35 am
There is a list of working and non working Peripherals on the Wiki Page - have a check on there ;)
Daz
ypkdani
Fri Jun 01, 2012 10:37 am
Thanks, i found this: http://elinux.org/RPi_VerifiedPeripherals
I have bought a K400 wireless keyboard with touchpad and works fine!
PaulCheffus
Fri Jun 01, 2012 11:43 am
Alfadaz wrote:There is a list of working and non working Peripherals on the Wiki Page - have a check on there ;)
Daz
Hi
I have the same question but I would prefer not to use a powered hub and the Wiki list doesn't tell me whether the keyboard and mouse specifically requires one.
It just mentions "Please be aware that some of these keyboards were probably used with a powered hub" which doesn't really help me much.
Cheers
Paul
Procrastination - The Thief of Time.
piglet
Fri Jun 01, 2012 12:12 pm
PaulCheffus wrote:It just mentions "Please be aware that some of these keyboards were probably used with a powered hub" which doesn't really help me much.
I've updated the (not my original) entry for the two keyboard models I've used:
Dell:
SK-8135 (B) (Rated 1.5A. Takes too much power from pi even when not used as USB hub. Symptom = repeated keystrokes)
SK-8115 (B) (Rated 100mA. Works directly in pi)
I have had no problems with the 8115. It's a good sturdy keyboard too. Takes a lot of abuse (think utube Angry German Kid).
lunchb0x
Thu Jun 07, 2012 9:28 pm
ypkdani wrote:Thanks, i found this: http://elinux.org/RPi_VerifiedPeripherals
That's strange, I also have a K400 and it kernel panics when I hit the enter button.
pete_l
Thu Jun 07, 2012 10:48 pm
In the spirit of a £30 embedded computer, I used a £5 ASDA keyboard and a £2.50 ASDA mouse. Both wok fine. Although if you plug them both into the onboard USB ports, there's nothing left for anything else. So I'd suggest splashing out for a £1.50 4-port USB hub - the sort with 4 USB connectors on short leads.
The first USB hub I tried crashed my RPi, but this one works fine.
MrMartini83
Wed Jun 13, 2012 6:59 am
I have also a Logitech K400, but I can't boot up when the WIFI dongle is connected during startup. If I plug it in, when the login screen appears, it works normally. I tried to use a USB 2.0 HUB with external power supply, but then I have the problem with repeating keystrokes...
southpaw
Wed Jul 04, 2012 2:31 pm
this lil cheapy working fine+dandy for me on weazy debian
http://www.ebuyer.com/225870-xenta-blac ... use-2-4ghz
Nr90
Wed Jul 04, 2012 2:33 pm
Another k400 owner here.
Mine works plugged straight into the pi with both Debian wheezy and arch
Montala
Wed Jul 04, 2012 2:36 pm
Nr90 wrote:Another k400 owner here.
Mine does also, although I haven't actually tried Arch yet, as I intend to concentrate on Wheezy for a bit!
PaulCheffus
Wed Jul 04, 2012 5:43 pm
Hi
Another happy user of the k400 here, no issues on wheezy.
Cheers
Paul
MatthewT
Wed Jul 04, 2012 5:55 pm
For anyone interested, I'm using an Argos value wireless deskset which comes with a mouse, keyboard and small dongle that sits nicely in the pi. Currently on sale for £10 and works fine with Debian.
Return to “Beginners”
