TeNNoX
superblock error, unable to boot
Wed Mar 05, 2014 6:21 pm
My Raspberry Pi was used as a webserver untill it just went offline... When I checked the output via HDMI this came up:
I then tried to fix the issue by booting another linux on my laptop, putting in the SDCard and then using fsck to fix the error...
fsck said something like unknown magic value and bad superblock...
e2fsck with the backup superblock positions from
"mke2fs -n /dev/mmcblk0p2" did not work either (mke2fs did not work with mmcblk0 or mmcblk0p1!)
Re: superblock error, unable to boot
Wed Mar 05, 2014 7:42 pm
Time to build a new SDcard from your archived backup.
The one you've got appears to be worn out.
When you've rebuilt a fresh one get the latest firmware and software packages.
sudo apt-get update
sudo apt-get upgrade
sudo rpi-update
sudo reboot
Then create a fresh archived backup.
Languages using left-hand whitespace for syntax are ridiculous
DMs sent on Twitter/LinkedIn will be answered next month.
The use of crystal balls and mind reading is prohibited.
TeNNoX
Fri Mar 07, 2014 6:36 am
Is the SDCard broken or can I just reformat it and reuse it?
Fri Mar 07, 2014 8:28 am
TeNNoX wrote:Is the SDCard broken or can I just reformat it and reuse it?
It depends on whether the failure was caused by wear levelling.
TeNNoX
Fri Mar 07, 2014 2:15 pm
DougieLawson wrote: It depends on whether the failure was caused by wear levelling.
How do I know that?
Fri Mar 07, 2014 3:57 pm
How do I know that?
Reformat, rebuild, reboot and wait for the next failure.
simonmcc
Mon Mar 10, 2014 10:00 am
TeNNoX wrote:My Raspberry Pi was used as a webserver untill it just went offline... When I checked the output via HDMI this came up:
I had good success with repairing my superblock using instructions like these:
http://www.recantha.co.uk/blog/?p=1208
I think the suggestions from others, about starting with a fresh image again are good advice too.
simonmcc.blogspot.com/search/label/pi
