Zironid
Help with 180 servo
Wed Mar 05, 2014 4:58 pm
Hello.
I'm working on a project called "The candy box", which is a box that open a little door with a servo when you press your button, so it can administrate the candies (my father and me eat them without noticing it, so my mather and sister get angry :oops: )
Anyway. when I was working on the project, I conected the servo (a TowerPro SG92R, works from 3V to 6V) to the 5V pin of the RasPi, and everything works properly. When y powered the servo with an external source, a 5V-1A supply or an Arduino UNO, starts rotating in 360° continuously (like a normal dc motor), when it's supposed to rotate only 180°. The servo works fine with the UNO and with the Pi (as long as I connect it to the power rails of the Pi), so isn't broken.
¿What's happening? ¿Is there something I don't know about servos?
A cyclop just have two moods: angry and asleep. - MTG card
joan
Re: Help with 180 servo
Wed Mar 05, 2014 5:07 pm
It sounds like it's broken. A TowerPro SG92R is not a continuous rotation servo. Where did you buy it?
Zironid
Wed Mar 05, 2014 5:13 pm
It had come with an Arduino starter kit. In fact, the "stops" of the servo are broken, bit it works quite well, stops in the point I'm telling him.
joan
Wed Mar 05, 2014 5:28 pm
Zironid wrote:It had come with an Arduino starter kit. In fact, the "stops" of the servo are broken, bit it works quite well, stops in the point I'm telling him.
I'm a bit surprised it's still usable. My (cheap) servos stay broken when I force them past the end-stops.
Zironid
Wed Mar 05, 2014 7:53 pm
The servo (theoricaly) still working. This is the very first time yhay I use it with the Pi. I've use it with the Arduino, using the Arduino power pins (conected to my computer and whit an external power supply). But when I tried to power it with an external suply start working like that. :?
