Raspimina
curl --ftp how to manage directories
Mon Mar 03, 2014 3:57 pm
Hi to all the community,
im using this code to upload all file from folder /data/386/file.log
find /data/386 -type f -exec curl -u user:pass --ftp-create-dirs -T {} ftp://myftp.com/data/Post1/{} \;
the final result is: ftp://myftp.com/data/Post1/data/386/file.log
how can i change the code to obtain this result? ftp://myftp.com/data/Post1/file.log
thanks :oops:
jojopi
Re: curl --ftp how to manage directories
Mon Mar 03, 2014 5:36 pm
Do not specify {} in the FTP URL. Just the directory with a trailing slash.
Raspimina
Mon Mar 03, 2014 8:03 pm
Sorry con you edit/correct my code? :oops:
Raspimina
Mon Mar 03, 2014 11:08 pm
i made some test, thats the correct code:
must delete only the last {}
find /data/386 -type f -exec curl -u user:pass --ftp-create-dirs -T {} ftp://myftp.com/data/Post1/ \;
thank you very much!!!
Raspimina
Tue Mar 04, 2014 11:17 pm
there is a problem with the code, now it upload only the file, without any sub folders!
find /data -type f -exec curl -u user:pass --ftp-create-dirs -T {} ftp://myftp.com/data/Post1/ \;
i need to upload this part: /data/386/file.log
with the code at the beginning of this post i optain this: ftp://myftp.com/data/Post1/file.log
how can i change the code to obtain this result? ftp://myftp.com/data/Post1/386/file.log
jojopi
Wed Mar 05, 2014 12:01 am
Raspimina wrote:i need to upload this part: /data/386/file.log
The easiest way is to be in the directory /data locally, so that the local name {} includes 386/file.log but not /data/. Then, put the {} back onto the destination:
cd /data && find * -type f -exec curl -u user:pass --ftp-create-dirs -T {} ftp://myftp.com/data/Post1/{} \;
Raspimina
Wed Mar 05, 2014 7:03 am
Great! Thanks very much!
It's a very easy solution :)
