lilzz
looking for a simple potentiometer cir interface with Pi;
Mon Mar 03, 2014 6:14 am
What's a simple analog potentiometer circuit that interfaced with the pi? DO I need a Ardino circuit?
ame
Re: looking for a simple potentiometer cir interface with Pi
Mon Mar 03, 2014 6:24 am
Searching for "raspberry pi potentiometer" on Google gets me this:
http://learn.adafruit.com/reading-a-ana ... i/overview
Richard-TX
Mon Mar 03, 2014 6:40 am
It doesn't get muich simpler than this:
http://www.ebay.com/itm/1PC-New-AD-DA-C ... 2c71d20f9d
It even has it's own pot on board which you can disconnect and hook up your own.
$1.91 delivered.
I use these as a current detector.
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
lilzz
Mon Mar 03, 2014 6:56 am
Richard-TX wrote:It doesn't get muich simpler than this:
$1.91 delivered.
Is that mean I also need to get a Arduino board too?
ame
Mon Mar 03, 2014 7:27 am
$1.91 delivered.
No, you hook it up to the I2C interface on the GPIO pins.
Richard-TX
Mon Mar 03, 2014 11:47 am
With the ADC board hooked up to the Rpi, the value read from the ADC will be relative position of the pot. There will be 255 steps from one stop to the other.
Richard
pluggy
Mon Mar 03, 2014 5:16 pm
The potentiometer outputs an analogue voltage and the Pi doesn't do analogue. The Arduino does do analogue, so you can use either an ADC board or an Arduino. With some devious coding and a few carefully chosen passive components you can bodge a pseudo analogue with just a digital device like the Pi, but if you're asking questions at this level on here, an ADC/Arduino is a lot easier.
