berry150
[Solved] Please help me install a module?
Sat Mar 01, 2014 2:46 am
first off I am really new to linux so please bear with me...
I'd like to install a module called SoundAnalyse so that I can run this code.
I tried this command:
pi@raspberrypi ~ $ sudo apt-get install python-SoundAnalyse
then I get
E: Unable to find a source package for python-SoundAnalyse
Then I tried installing the module with virtualenv:
(myenv)pi@raspberrypi ~ $ sudo pip install SoundAnalyse
result:
Downloading/unpacking SoundAnalyse
  Downloading SoundAnalyse-0.1.1.tar.gz
  Running setup.py egg_info for package SoundAnalyse
Installing collected packages: SoundAnalyse
  Running setup.py install for SoundAnalyse
    building 'analyseffi' extension
    gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/usr/include/python2.7 -c analyseffi.c -o build/temp.linux-armv6l-2.7/analyseffi.o
    analyseffi.c:1:20: fatal error: Python.h: No such file or directory
    compilation terminated.
    error: command 'gcc' failed with exit status 1
    Complete output from command /usr/bin/python -c "import setuptools;__file__='/home/pi/build/SoundAnalyse/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --single-version-externally-managed --record /tmp/pip-jWJicR-record/install-record.txt:
    running install
running build
running build_py
creating build
creating build/lib.linux-armv6l-2.7
copying analyse.py -> build/lib.linux-armv6l-2.7
running build_ext
creating build/temp.linux-armv6l-2.7
Command /usr/bin/python -c "import setuptools;__file__='/home/pi/build/SoundAnalyse/setup.py';exec(compile(open(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --single-version-externally-managed --record /tmp/pip-jWJicR-record/install-record.txt failed with error code 1 in /home/pi/build/SoundAnalyse
Storing complete log in /root/.pip/pip.log
Could someone explain to me (step by step, in a noob-friendly way) how to install SoundAnalyse?
Thanks in advance!
EDIT:
OS: raspbian from noobs v 1.3.4
python v 2.7.3
elParaguayo
Re: Please help me install a module?
Sat Mar 01, 2014 7:20 am
Do this first:
sudo apt-get install python-dev
and then rerun your last command.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
berry150
Sat Mar 01, 2014 12:35 pm
It worked! Thank you for answering.
Return to “Python”
