This may not be a beginner project. If not, well, we'll just find out, won't we?
I have a new RPi coming tomorrow-ish. Assuming everything works, I eventually want to set up, as the title indicates, a file and audio server. I intend on (eventually) getting a powered USB hub since the HDD I have runs off of USB power, and I don't want to blow out the Pi.
What I want to do: access files and stream audio remotely to my Samsung Galaxy S4, Asus TF700 tablet, and any computer via the Internet.
What I know I need: SD card w/ Raspbian, Raspberry Pi, HDD with files, Internet connection (WiFi or Ethernet, the latter preferred), powered USB hub, router.
I know I need to set up the router to allow access on various ports to the Raspberry Pi, and probably set up a separate account in Raspbian to deal with the files I know I will want to work with on the HDD. I'll set up SSH and install a VNC server on the RPi so I have graphical access to files. I know I can modify files on the device using both of these, so a false file server idea can work there. (Not really a file server, but access to files) How can I transfer files between the two? Set up SFTP? How can I stream audio between the two? Can I use something like Winamp to call a playlist file on the RPi, sort of like how ShoutCast works?
Any help, thoughts, or ideas would be appreciated.
