stephencbingham
Composite video in b/w
Thu May 31, 2012 10:46 am
I've trawled through the forum & haven't seen anything about composite video connections only being in black & white.
At the moment my R-Pi is connected to an old crt portable via a SCART adapter. Unfortunately there's no colour.
I'm hoping to get a new screen & hopefully use a(n) hdmi connector.
I am curious as to why I only get b&w, is there a setting I should be invoking?
Rgds
Burngate
Re: Composite video in b/w
Thu May 31, 2012 12:08 pm
Is the TV PAL only? Some would show NTSC in mono only. There's a setting in config.txt for PAL - somewhere!
bredman
Thu May 31, 2012 12:12 pm
This is a know problem when using old European TVs which do not support NTSC. You should set the video mode to PAL, see http://elinux.org/RPi_config.txt#Video_mode_options
dom
Thu May 31, 2012 12:14 pm
texy
Thu May 31, 2012 12:32 pm
Why is NTSC the default setting?
Texy
