best97
Run script at boot
Tue Feb 25, 2014 2:40 pm
Hi, I have a script file and I would like that that script was executed in every single boot, how can I do that?
I searched and nothing worked... I'm new in the rasp and linux, so I don't know much...
Thank you
lorenz92
Re: Run script at boot
Tue Feb 25, 2014 4:05 pm
There are actually several ways for doing that.
One way I used in a project of mine (which I prefer) is by using the init run-level based rc scripts.
Basically you will encounter the command "service" to start and stop system services i.e. your personal service.
Following this method you will also have the possibility of doing "service <your script> start" for example, which is neat and handy.
NOTE: the following steps usually require root permissions. So just issue every command with sudo or log into a root shell (sudo -s, beware that everything you do is done with root permissions!!)
# update boot / reboot files
cp <your script> /etc/init.d/
# do it as soon as the device is going down,
#   both for shutdown and reboot
update-rc.d /etc/init.d/<your script> defaults
(If I couldn't have been clear enough, this has to be done after looking at the following part...)
The <your script> part is something like the following:
#! /bin/sh
### BEGIN INIT INFO
# Provides:          <your script name>
# Required-Start:    $all
# Required-Stop:
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: Manage my cool stuff
### END INIT INFO
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/opt/bin
. /lib/init/vars.sh
. /lib/lsb/init-functions
# If you need to source some other scripts, do it here
case "$1" in
  start)
    log_begin_msg "Starting my super cool service"
# do something
    log_end_msg $?
    exit 0
  stop)
    log_begin_msg "Stopping the coolest service ever unfortunately"
    # do something to kill the service or cleanup or nothing
    log_end_msg $?
    exit 0
    echo "Usage: /etc/init.d/<your script> {start|stop}"
    exit 1
esac
That's it :)
Another way (but hackish) I used to do on an embedded system (but because that was not a debian, so beware, it seems more simple but an update of the system might screw it up) is to modify the /etc/profile.
best97
Tue Feb 25, 2014 8:15 pm
Ok, thank you :), just have a couple of questions.
When I run:
In the <you script>, should I put my script name or the path to my script? If it is the name, does it matter if it is in the pi folder?
And I didn't get what I have to do when you say:
"The <your script> part is something like the following:
#! /bin/sh
### BEGIN INIT INFO
# Required-Stop:
### END INIT INFO
. /lib/init/vars.sh
case "$1" in
  start)
# do something
    log_end_msg $?
    exit 0
  stop)
    log_end_msg $?
    exit 0
    exit 1
esac
Do I have to create another file with this?
My script is very simple:
#!/bin/sh
sudo service hostapd stop
sudo service udhcpd stop
sudo service hostapd start
sudo service udhcpd start
Thank you so much for helping me :)
lorenz92
Tue Feb 25, 2014 8:23 pm
Yes, <your script> is a path. If the script is in the current directory (i.e. the one at prompt) then actually you can just type its name.
Useless to say, avoid spaces ...
Sorry I was in a hurry and I did not really spent too much words :D
So, exactly, you have to create yet another script. Just copy and paste my template.
Then replace # do something with the content of your original script, to say:
service udhcpd stop
NOTE: why not sudo? Simple :) The script, if directly executed by the system is trivially executed as root. If issued by the user, the same here, it is implicit -> sudo service myservice...
Hope this can help, otherwise just poke here your doubts.
best97
Tue Feb 25, 2014 9:09 pm
Thank you, so I just edited the template, is it ok like this? (my script is called "hotspot" and it is in the pi folder)
#! /bin/sh
### BEGIN INIT INFO
# Provides:          </home/pi/hotspot>
# Required-Stop:
### END INIT INFO
. /lib/init/vars.sh
case "$1" in
  start)
    log_begin_msg "Starting my Hotspot service"
service udhcpd stop
    log_end_msg $?
    exit 0
  stop)
    log_begin_msg "Stopping the Hotspot service unfortunately"
    log_end_msg $?
    exit 0
    echo "Usage: /etc/init.d/home/pi/hotspot {start|stop}"
    exit 1
esac
If everything is ok, what sould I do next? run the next 2 commands as sudo?
In these 2 commands <your script> is the path of the script that I just created from your template?
Thank you so much for helping me! :D :D :D :D :D :D
lorenz92
Tue Feb 25, 2014 10:19 pm
Yes
and
Yes
sudo is usually required when writing / entering system directories (notably /etc tree).
Let me know!
EDIT: I noticed a minor problem (actually, I don't really know if it is a problem)
it should be
# Provides: hotspot
best97
Tue Feb 25, 2014 11:06 pm
I changed the #Provides and then ran the commands
cp /home/pi/hotspotboot /etc/init.d/
update-rc.d /etc/init.d/home/pi/hotspotboot defaults
And it gives me an error:
root@raspberrypi:/home/pi# cp /home/pi/hotspotboot /etc/init.d/
root@raspberrypi:/home/pi# update-rc.d /etc/init.d/home/pi/hotspotboot defaults
update-rc.d: using dependency based boot sequencing
update-rc.d: error: unable to read /etc/init.d//etc/init.d/home/pi/hotspotboot
What should I do?
Thank you :)
-----------------------------EDIT--------------------
I correct it, I did
cd /etc/init.d/
update-rc.d hotspotboot defaults
but now it gives me this error:
oot@raspberrypi:/etc/init.d# update-rc.d hotspotboot defaultsupdate-rc.d: using dependency based boot sequencing
update-rc.d: warning: default start runlevel arguments (2 3 4 5) do not match hotspotboot Default-Start values (     2 3 4 5)
update-rc.d: warning: default stop runlevel arguments (0 1 6) do not match hotspotboot Default-Stop values (      0 1 6)
insserv: script hotspotboot is not an executable regular file, skipped!
insserv: warning: script 'mathkernel' missing LSB tags and overrides
What should i do?
Wed Feb 26, 2014 5:09 am
The only line to really worry about is
This is because you haven't got the eXecute flag set on the file.
Try
cd /etc/init.d
sudo chmod u+x hotspotboot
You will still get some warnings, but the error I mentioned above should have gone.
lorenz92
Wed Feb 26, 2014 7:35 am
Oh yes indeed, I forgot to tell you that...
The problem is for sure about executable bit ("+x").
best97
Wed Feb 26, 2014 8:18 am
I tryied that and then this appeared, i belive it is an error:
insserv: missing valid name for `Provides:' please add.
(just for you to know, My provides is like this: # Provides: hotspot)
What should I do?
iinnovations
Sat Mar 01, 2014 5:32 pm
It is much simpler to add your commands to the end of /etc/rc.local . Having a system service is nice, but an unnecessary level of complication for simple tasks.
Typically, I create a boot.sh script, invoke it from rc.local. Then I can keep boot.sh in a git repo or somewhere else handy.
As for the commands invoked here, you should probably just configure your dhcp and access point to not start on boot and turn them on when you want. I do this via a boot script as well, but using python. I have a python call read network configuration from a database and then act accordingly. Remember that you can invoke python scripts from rc.local as well.
Colin
CuPID Controls :: Open Source browser-based sensor and device control
interfaceinnovations.org/cupidcontrols.html
cupidcontrols.com
Biruntha
Sun Nov 22, 2015 1:00 am
what you mentioned <your script>. is it python script?
how can i change this steps to python script?
DirkS
Sun Nov 22, 2015 1:06 am
Biruntha wrote:what you mentioned <your script>. is it python script?
To which post are you referring?
Keep in mind that you're responding to a topic that's a year and a half old...
Biruntha
Sun Nov 22, 2015 1:38 am
second post
fixermark
Wed Jul 20, 2016 1:55 am
Your script included the line
The < and > characters (and possibly also the forward-slash?) aren't accepted in that context. Provides should be the name of the capability your init script is providing to the system, something more like "hwclock" or "alsa-utils". In your case,
# Provides:          hotspot
... would probably be appropriate.
