civic
How to reverse a motor direction through ESC
Sat Feb 22, 2014 11:24 pm
I am using PIGPIO http://abyz.co.uk/rpi/pigpio/ library to control a brushless motor (1/16) with ESC (25A).
I am successful getting the motor to run in one direction with the help of soft PWM signal.
The problem is, I am not sure how to reverse the direction of motor. I don't want to exchange the wires externally. But I want it to reverse its direction by sending a signal.
Is there a way I can send a signal to ESC from Raspbeery Pi to achieve this. (According to manual : My ESC has the capability to reverse. It does not say anything about how to do it.)
Thanks,
Kind Regards.
kweenie
Re: How to reverse a motor direction through ESC
Mon Feb 24, 2014 6:46 pm
it seems there are many different ways to do what you want.
the best way seems to do some reading on H-bridge devices.
i understand very little of electronics but the internet tells all :)
i ordered a Hbridge device and will start some experimenting in march , when i have that working i will let you know .
joan
Mon Feb 24, 2014 7:24 pm
Do you have a link to the specs of your ESC or the model number?
civic
Sat Mar 01, 2014 3:42 pm
@kweenie :) thanks a lot. OK I will have a read through H-bridge devices, and If I find something, will let you know and waiting to hear from you.
@ joan, I do not have a link to ESC as such, but I know few spec as below,
Motor: 4800KV Brushless Inrunner (2040)
ESC: 25A Brushless (with Reverse)
It comes with buggy and the link to it,
http://www.hobbyking.com/hobbyking/stor ... ystem.html
If you need more info, I can speak to the customer service there and get the spec of you.
Thanks and Regards
GTR2Fan
Sat Mar 01, 2014 4:04 pm
If ESCs still work on the same principal as when I built mine to run from a standard 27MHz Futaba RC receiver over 20 years ago, it's all in the mark-space ratio with equivalent servo positions of fully ccw=full speed reverse, fully cw=full speed forward, and centre=stop.
Pi2B Mini-PC/Media Centre: ARM=1GHz (+3), Core=500MHz, v3d=500MHz, h264=333MHz, RAM=DDR2-1200 (+6/+4/+4+schmoo). Sandisk Ultra HC-I 32GB microSD card on '50=100' OCed slot (42MB/s read) running Raspbian/KODI16, Seagate 3.5" 1.5TB HDD mass storage.
joan
Sat Mar 01, 2014 4:15 pm
civic wrote: ...
Try sending different pulse rates from the command line.
sudo pigpiod # start the daemon
pigs servo n 1500 # mid-point
pigs servo n 1000 # counter clockwise?
pigs servo n 2000 # clockwise?
where n is the Broadcom gpio number attached to the servo.
I've seen a similar query. ESCs seem to require a set sequence to reverse direction (safety reasons). Trouble is I think the sequence required varies with model.
