I have a headless ALARM pi sharing my music library via NFS, after a few hours my library becomes unavailable on the network. The library is stored on a (powered) USB drive connected to the pi. If I log on the server, the directory where the drive is mounted is not accessible, with input/output error...
See the following output of lsusb and dmesg:
[root@piserver medialibrary]# lsusb
Bus 001 Device 004: ID 13fd:1340 Initio Corporation Hi-Speed USB to SATA Bridge
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. SMC9512/9514 USB Hub
[ 6.190629] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 6.418093] systemd-journald[70]: Received request to flush runtime journal from PID 1
[ 18.090430] EXT4-fs (sda1): mounting ext3 file system using the ext4 subsystem
[ 18.403991] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 18.466622] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 18.895548] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 19.840039] NFSD: starting 90-second grace period (net c0839040)
[ 20.187732] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[ 5270.175709] hub 1-1:1.0: port 3 disabled by hub (EMI?), re-enabling...
[ 5270.185374] usb 1-1.3: USB disconnect, device number 4
[ 5270.536662] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 5270.638160] usb 1-1.3: New USB device found, idVendor=13fd, idProduct=1340
[ 5270.638198] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5270.638215] usb 1-1.3: Product: External
[ 5270.638229] usb 1-1.3: Manufacturer: Generic
[ 5270.638245] usb 1-1.3: SerialNumber: 57442D574341533831303838
[ 5270.656639] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[ 5270.663782] scsi1 : usb-storage 1-1.3:1.0
[ 5271.657721] scsi 1:0:0:0: Direct-Access Generic External 2.10 PQ: 0 ANSI: 4
[ 5271.661909] sd 1:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 5271.663235] sd 1:0:0:0: [sdb] Write Protect is off
[ 5271.663278] sd 1:0:0:0: [sdb] Mode Sense: 21 00 00 00
[ 5271.664529] sd 1:0:0:0: [sdb] No Caching mode page found
[ 5271.681680] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[ 5271.705009] sd 1:0:0:0: [sdb] No Caching mode page found
[ 5271.719878] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[ 5278.237500] sdb: sdb1
[ 5278.244885] sd 1:0:0:0: [sdb] No Caching mode page found
[ 5278.260551] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[ 5278.270914] sd 1:0:0:0: [sdb] Attached SCSI disk
[11054.334913] EXT4-fs error (device sda1): ext4_find_entry:1309: inode #23232513: comm nfsd: reading directory lblock 0
[11054.426675] EXT4-fs error (device sda1): ext4_find_entry:1309: inode #23232513: comm nfsd: reading directory lblock 0
[97620.966149] EXT4-fs (sda1): error count: 2
[97620.966188] EXT4-fs (sda1): initial error at 1392850801: ext4_find_entry:1309: inode 23232513
[97620.966213] EXT4-fs (sda1): last error at 1392850801: ext4_find_entry:1309: inode 23232513
[111918.384709] EXT4-fs error (device sda1): ext4_find_entry:1309: inode #23232513: comm nfsd: reading directory lblock 0
