Gigabyte2
GPIO control from a web page
Tue Feb 18, 2014 9:09 pm
Hi, I wrote a Python script for controlling sensor values and relays.
I need to manage GPIO outs in a web page. I'm looking for a "button" that sets the output True when it is False and vice versa.
How I can do this?
Thank you :mrgreen:
mescgroup
Re: GPIO control from a web page
Tue Feb 18, 2014 9:44 pm
Howdy, if I understand your question, there is a great example of doing something similar here:
http://www.instructables.com/id/Simple- ... ur-Raspbe/
Gigabyte2
Tue Feb 18, 2014 10:10 pm
Thank you!
I have downloaded the package from the link at the bottom of page.
Now I can't set the GPIO pins, I could set only pins 19, 21, 23.
ondrej1024
Fri Feb 28, 2014 8:08 am
Hi Gigabyte2
I am developing a software to control relay cards remotely via various user interfaces. With the latest version also controlling GPIO pins is supported.
The software has a built-in webserver and provides its own web GUI. But it also provides an HTTP API which you can use to send HTTP requests from your own custom web page to control the GPIO pins.
You can have a look at the projects GitHub page to see if this is what you need:
http://ondrej1024.github.io/crelay
Cheers, Ondrej
The Telegea.org project: https://www.telegea.org
Tarcas
Fri Feb 28, 2014 3:36 pm
Gigabyte2 wrote:Thank you!
Make sure you're using the Broadcom numbering scheme when you're identifying which pins you're looking at. (It's confusing, there are at least 3 ways to identify each pin. Maybe more.)
iinnovations
Sat Mar 01, 2014 7:51 am
I prefer to separate the IO control from the interface, using python to control the IO from set values stored in a database. The UI then interfaces with the database. It facilitates many features, such as logging, foreign key constraints, etc.
CuPID Controls :: Open Source browser-based sensor and device control
interfaceinnovations.org/cupidcontrols.html
cupidcontrols.com
Sat Mar 01, 2014 11:19 am
iinnovations wrote:I prefer to separate the IO control from the interface, using python to control the IO from set values stored in a database. The UI then interfaces with the database. It facilitates many features, such as logging, foreign key constraints, etc.
I don't use a database. I use MQTT to separate the GPIO from the CGI.
https://www.ibm.com/developerworks/comm ... x_and_gpio
This is a doctor free zone.
iinnovations
Sun Mar 02, 2014 1:03 am
cgi is slow, and database is good. wsgi is great. I lost an order of magnitude on server response time, not to mention on multiple concurrent requests, by making the switch.
cupidcontrols.com
iinnovations
Sun Mar 02, 2014 1:05 am
I see, you use fastcgi. I find it easier to use wsgi and apache2 ... no wonder django uses it. It's plug and play and fast.
cupidcontrols.com
thisisqasim
Wed May 10, 2017 2:10 pm
Since I couldn't find a better solution, I made a very simple web UI to toggle GPIO pins on/off. You are welcome to check it out and contribute.
https://github.com/ThisIsQasim/WebGPIO
baris93pau
Thu Jun 08, 2017 1:42 pm
Hi, i controlled the gpio pins from a web page with two buttons and i also want to control motor speed with a slider. How can i do it?
