Edit* I'm pretty sure this will be asked, Of course it is the usb 2.0 version not the pci express.
redhawk wrote:Well according to https://www.diamondmm.com/tvw600usb-ati ... d-600.html there are drivers for Windows 7 unless you're using 64bit version.
I also understand that Windows 7 does provide some level of backwards compatibility for Vista drivers so in failing that try the Vista 64bit ones.
As for the Pi compatibility you're going to have to plug the dongle into the USB port and report back the USB vendor ID code with: lsusb
You may have to insert the dongle before Pi is switched on since a power hungry device it's likely to cause the Pi to reboot on startup.
Richard S.
Can this be done on raspian though? I like raspBMC but it is a little slow.LetHopeItsSnowing wrote:Or you could use it to turn your Pi into a PVR with raspbmc
http://www.stuffaboutcode.com/2013/03/r ... v-pvr.html
