I'm new on this forum and I would like to share a little project I made to stream audio content from a bluetooth source (a phone for example) to the raspberry jack output.
I spent a lot of time to get information from different sources and use a part of each to make my raspberry doing what I wanted. I didn't find any complete tutorial to do it and I think it can be interesting for people who want to have the same use of their raspberry PIs.
I recently saw some wireless bluetooth speakers that are able to play music from a remote device using a standard named A2DP (Advanced Audio Distribution Profile). A2DP is a bluetooth profile that many devices support in a native way.
This system is really interesting because you can easily listen music everywhere, just keeping your portable speaker with you. Nevertheless, when your are at home and have a complete audio system (audio amplifier with speakers), it's quite disapointting to listen music on a little portable speaker as you could have a much better sound with your audio system. You have another solution that is to connect your phone with an adapted jack wire but in this case, your phone is plugged in your audio system and you can't freely use it at the same time : it's not very practical...
The advantage of this bluetooth standard comparing to other audio streaming solutions using Upnp protocol for example is that you simply redirect your phone audio output and use what you want to play music. In other terms, your are not dependent of a particular player or application to listen music on your phone : the only condition is that the thing you use makes sound. I was particularly interested in this solution because I use a lot online music providers such as Spotify or Deezer, so I couldn't easily use Upnp solutions because my music is not saved on my phone as classical Mp3 files. With this solution you can play sound from any source on your phone : a particular application, your internet browser, your local Mp3 player, a call you receive...
So let me introduce my solution.
First of all the required things :
- a raspberry Pi (I have a raspberry type B but I think it can also work with a type A)
- an SD card with the lastest raspbian distribution (I use 2013-09-25-wheezy-raspbian)
- a compatible USB bluetooth adapter (I bought one very simple from the french provider "Boulanger" which perfectly works whithout any additionnal driver. The internal bluetooth chip is made by Cambridge Silicon Radio. A list of compatible hardware is available at the following address : http://elinux.org/RPi_VerifiedPeripherals)
- a bluetooth audio device which supports the A2DP audio profile. I personnaly use my phone to stream some music : a samsung galaxy s4 which runs android 4.3. I think that most of android phones support it. I haven't tried with apple devices or Windows phones but it probably works. Even some older phones should work.
- an headset or a jack wire (connection to an audio amplifier input) to get sound from the raspberry jack ouput
- some basic knowledge of linux (use of terminal commands, edit files)
Remark : if you already have others USB devices connected to your raspberry, you can use an external powered usb hub. It can solve some problems if your devices require important power to work : the power that the raspberry can provide your usb devices with is limited. If you only use a bluetooth adapter, it is not necessary.
I assume that you have a ready-to-use raspberry pi and you know how to access it (with a screen, keyboard and mouse or directly from another computer thanks to an ssh connection). If not, there are a lot of good tutorials on the internet and I'm sure you will manage to do it (Google is your friend
If you already have a raspbian distribution on your raspberry and you customized it with a lot of personnal settings, I suggest you to re-install a clean version : it will prevents you from facing some addtionnal configuration problems (you can save your current image before trying it).
So the first thing you have to do is to plug your bluetooth USB adapter and to switch on your raspberry. Your adapter should begin to blink if it is equiped with an activity LED.
Then, you have to log on your raspberry as the default "pi" user and to open a terminal (if you use a ssh connection you are already on a terminal window) : all will be done from it !
1. Install required packages
Update your repositories list to make sure you will find all the required packages :
sudo apt-get update
Download and install the bluez component, the pulse-audio bluetooth module and some other required dependencies :
sudo apt-get install bluez pulseaudio-module-bluetooth python-gobject python-gobject-2
Add the default user "pi" to the lp group (you will be able to see bluetooth sources and to change some bluetooth settings) :
sudo usermod -a -G lp pi
sudo nano /etc/bluetooth/audio.conf
Enable=Source,Sink,Media,Socket
sudo nano /etc/pulse/daemon.conf
resample-method = trivial
sudo reboot
Display the current bluetooth configuration :
sudo hciconfig -a
hci0: Type: BR/EDR Bus: USB
BD Address: XX:XX:XX:XX:XX:XX ACL MTU: 192:8 SCO MTU: 64:8
UP RUNNING PSCAN
RX bytes:2035 acl:0 sco:0 events:119 errors:0
TX bytes:467 acl:0 sco:0 commands:50 errors:0
Features: 0xff 0xff 0x8f 0xf8 0x18 0x18 0x00 0x80
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH HOLD SNIFF PARK
Link mode: SLAVE ACCEPT
Class: 0x4e0100
Service Classes: Networking, Rendering, Capturing, Telephony
Device Class: Computer, Uncategorized
HCI Version: 1.2 (0x2) Revision: 0x7c5
LMP Version: 1.2 (0x2) Subversion: 0x7c5
Manufacturer: Cambridge Silicon Radio (10)
You can change the name of your USB bluetooth adapter as it will be visible by remote devices from the following file, where XX:XX:XX:XX:XX:XX represents the bluetooth address of your USB adapter :
sudo nano /var/lib/bluetooth/XX:XX:XX:XX:XX:XX/config
Another configuration file can be interesting :
sudo nano /etc/bluetooth/main.conf
Enable the bluetooth connection on your phone (or other device), and activate the public visibilty
Launch a bluetooth scan on your raspberry :
sudo hcitool scan
Try to send a bluetooth ping to your phone, where XX:XX:XX:XX:XX:XX represents your phone bluetooth address :
sudo l2ping XX:XX:XX:XX:XX:XX
sudo hcitool cc XX:XX:XX:XX:XX:XX
Activate the ISCAN service on your raspberry to make it visible from other devices :
sudo hciconfig hci0 piscan
UP RUNNING PSCAN ISCAN
bluez-simple-agent
A "Enter Pin :" message should appear on your raspberry asking you for the PIN code : enter the same code you just defined on your phone and press enter. If you try to connect your phone without stopping the bluez-simple-agent, you should be asked to authorize the connection (message "Authorize connection (yes/no):").
Your phone is now paired. You can stop the bluez service by pressing Ctrl+C.
Add your phone to the bluetooth trusted devices (you will not be obligated to enter the PIN code each time you want to connect your phone to your raspberry), where XX:XX:XX:XX:XX:XX represents your phone bluetooth address :
bluez-test-device trusted XX:XX:XX:XX:XX:XX yes
Once your phone is connected, you will see it as the bluetooth source n°1 :
pactl list sources short
0 alsa_output.platform-bcm2835_AUD0.0.analog-stereo.monitor module-alsa-card.c s16le 2ch 44100Hz SUSPENDED
1 bluez_source.XX_XX_XX_XX_XX_XX module-bluetooth-device.c s16le 2ch 44100Hz SUSPENDED
pactl list sinks short
0 alsa_output.platform-bcm2835_AUD0.0.analog-stereo module-alsa-card.c s16le 2ch 44100Hz SUSPENDED
pactl load-module module-loopback source=bluez_source.XX_XX_XX_XX_XX_XX sink=alsa_output.platform-bcm2835_AUD0.0.analog-stereo
Change the default HDMI sound ouput for the jack output :
amixer cset numid=3 1
amixer set Master 100%
pacmd set-sink-volume 0 65537
This system works fine but requires a connection on your raspberry each time you want to listen music : you have to manually launch the command described on step 5 to connect the bluetooth source to the default sink though the loopback module. It means you must have a screen/keyboard/mouse connected or a network connection (ssh access) : it's not much practical, and maybe less than directly connecting your phone to your audio system though a jack wire...
I found that the lastest version of pulse audio (v4.0) includes a new module called "module-bluetooth-policy" that automatically activates the loopback module (connects the source to the sink) on each bluetooth device connection. Nevertheless, the pulse-audio version installed by default on raspbian is v2.0 (the command to get the version is : pulseaudio --version) and doesn't include such a module.
I installed the lastest version on my raspberry (it can be downloaded from here : http://www.freedesktop.org/wiki/Software/PulseAudio/) and tried to get it working with the bluetooth modules but I didn't manage to have something good (I didn't see any bluetooth source when I connected my phone and met other troubles). This is a more complicated job because you have to clone the source code from git repository, to configure makefiles, to resolve dependencies (many other packages to install), to build the application (compilation) and to deploy it on the right folders (installation).
So I decided to find another solution : a regular job that looks for a bluetooth device connection and automatically launchs the loopback module.
7. Configure pulse-audio in system mode (necessary to launch pulse without being logged on the raspberry)
Activate the pulse-audio system mode and allow module loading :
sudo nano /etc/default/pulseaudio
PULSEAUDIO_SYSTEM_START=1
DISALLOW_MODULE_LOADING=0
sudo adduser pi pulse-access
sudo nano /etc/pulse/client.conf
autospawn = no
allow-module-loading = yes
load-default-script-file = yes
default-script-file = /etc/pulse/default.pa
sudo nano /etc/dbus-1/system.d/pulseaudio-system.conf
<policy user="pulse">
<allow own="org.pulseaudio.Server"/>
<allow send_destination="org.bluez"/>
<allow send_interface="org.bluez.Manager"/>
</policy>
Create a new script file that will be regularly launched to check if a new bluetooth device have been connected and automatically launch the loopback module :
mkdir /home/pi/pulseAudioBluetooth
nano /home/pi/pulseAudioBluetooth/checkForBluetoothDevice.sh
Copy/paste the following code into the file :
#!/bin/bash
#This script looks for a bluetooth audio source and launch the pulse audio loopback module if necessary
#log traces :
#date=$(date "+%Hh%Mm%Ss")
#echo "Script Exec "$date
bluetoothSource=$(pactl list sources short | grep bluez_source)
read loopbackStatus < /home/pi/pulseAudioBluetooth/bluetoothLoopbackStatus.txt
if [[ $bluetoothSource != "" ]] && [[ $loopbackStatus == "0" ]]
then
source=${bluetoothSource:2:30}
pactl load-module module-loopback source=$source sink=alsa_output.platform-bcm2835_AUD0.0.analog-stereo
echo "1" > /home/pi/pulseAudioBluetooth/bluetoothLoopbackStatus.txt
#echo "command launched"
else
if [[ $bluetoothSource == "" ]] && [[ $loopbackStatus == "1" ]]
then
echo "0" > /home/pi/pulseAudioBluetooth/bluetoothLoopbackStatus.txt
#echo "reset loopbackStatus"
fi
fi
Make it executable :
sudo chmod u+x /home/pi/pulseAudioBluetooth/checkForBluetoothDevice.sh
echo 0 > /home/pi/pulseAudioBluetooth/bluetoothLoopbackStatus.txt
9. Planify a regular launch of the script
To do this, linux has an interessant service called cron that enable to planify scripts launching.
Open the cron configuration :
crontab -e
# automatically load loopback for new bluetooth devices (check every minute)
* * * * * /home/pi/pulseAudioBluetooth/checkForBluetoothDevice.sh >> /home/pi/pulseAudioBluetooth/cron.log 2>&1
Reboot your raspberry :
sudo reboot
If no sound is played after more than 1 minute, you probably have a problem : check the cron.log file (/home/pi/pulseAudioBluetooth/cron.log by default) to see if something is written in it (redirection of errors).
You can now stream music from your bluetooth device without connecting your raspberry to the network.
If you want to deactivate the automatic detection, juste delete the lines you added in the cron configuration file and reboot.
Enjoy your favorite music !
I hope I'm clear in my explanations and it will be useful to some people. Don't hesitate to give your feedbacks about this tutorial !
I would like to thanks people who spent some time to share their experience about audio streaming and more particularly the authors of these articles :
- http://kmonkey711.blogspot.fr/2012/12/a ... ry-pi.html
- https://wiki.archlinux.org/index.php/PulseAudio
Some others articles that can be interesting :
- http://doc.ubuntu-fr.org/pulseaudio
- http://colin.guthr.ie/2010/09/compiling ... -from-git/
