cobronc
DHT11 not working?
Thu Feb 06, 2014 8:36 am
[img]
[/img]Hi, i wired up the sensor power on pin 1, data on gpio4 (pin 7) and ground to pin 6 with jump wires,
installed the code following the adafruit tutorial (http://learn.adafruit.com/dht-humidity- ... re-install)
, but i am already stuck by trying to get the test temerature in the command line; all i get is : using pin4
and then everything hangs... any ideas?
I would appreciate any help, i am totally new at these things.
got stuck here:
all i get is using pin 4
and everything hangs...
Greets
Elly
Onira
Re: DHT11 not working?
Thu Feb 06, 2014 9:20 am
try another pin
Cogito ergo sum
cobronc
Thu Feb 06, 2014 2:09 pm
Tried pin 11 (gpio 17) but same result .. or no result. Is there another way besides the adafruit tutorial to check for eadings out of the sensor?
cobronc
Sun Feb 09, 2014 8:58 am
Nobody any idea?
Onira
Sun Feb 09, 2014 3:22 pm
have you made all necesarry setup needed?
Cogito ergo sum
cobronc
Sun Feb 09, 2014 4:09 pm
what do you mean by the setup? i followed the tutorial of adafruit.
greets
Onira
Sun Feb 09, 2014 5:53 pm
I ment all modules needed to be loaded and all the software needed to be installed.
Cogito ergo sum
cobronc
Sun Feb 09, 2014 5:59 pm
I followed this link exactly :
"$ git clone git://github.com/adafruit/Adafruit-Raspberry-Pi-Python-Code.git
$ cd Adafruit-Raspberry-Pi-Python-Code
$ cd Adafruit_DHT_Driver
Then run
sudo ./Adafruit_DHT type pin#
For example, we'll have an AM2302 connected to GPIO #4 so we'll run
sudo ./Adafruit_DHT 2302 4"
the program is starting, and writes using pin #4 then it hangs..
cobronc
Wed Feb 12, 2014 4:24 pm
I tried with installing the wiringPi module and program and all i get is
Data not good, skip
Is it possible a new sensor is broke?
Thu Feb 13, 2014 1:12 am
Check the wiring.
Red wire to physical PIN #1 (3V3)
Green wire to physical PIN #11 (GPIO #17)
Black wire to physical PIN #6 (GND)
Run your Adafruit python program with
sudo ./Adafruit_DHT 2302 17
if that doesn't work try
sudo ./Adafruit_DHT 2302 11
cobronc
Thu Feb 13, 2014 3:33 pm
I tried different pin numbering as you suggested, it is working now. Thanks everyone! :D
mahem
Thu Mar 17, 2016 5:35 am
I'm also having the same problem, But the above mentioned solution not working for me. Is anybody there to help??
